ARB intensity lights
LLRubylady
Lisa
NY
was an ā€˜18 Rubicon Mojito! now a boring Mazda
Silly question-these lights come with a switch but I assume that they can be hooked up to the aux switches? Any lights can be connected to the aux switches, correct?
JoeBelt
2018 Wrangler Unlimited Sahara
Sure. Just check the amperage to make sure the fuse will support the lights. Two of the aux switches are 40A and two are 15A.
LLRubylady
Lisa
NY
Glad I asked I didnā€™t think of that!
The specs are 6.1 a at 14.4 volts so I assume that both lights together are just over 12 amp so can go on the same aux? Or is it the volts?
JoeBelt
Correct, You can connect both lights to any aux switch you want without worry. It would make sense to use a switch that isnā€™t fused for 40A since you may want that for something later. Either way youā€™re in the clear!
word302
Oregon
JLU
Both together are still running at 14.4 volts. You can put them both on a single 15 amp circuit.
LLRubylady
Lisa
NY
Thanks for all the responses. Very helpful. I just wanted to be sure before ordering.
Highonlyfe
IA
2018 JLU Rubicon, 2011 JKU
Truly some of the best lights you can get.
Enjoy, ARB is tops, so good choice.
