Alex V
Correct, they are bolted on to steel bracket insideMakes sense as the hooks look like a bolt on from this latest JL bumper image off the Rival website.
This
Do you have a link for the pre order?
That bar in the picture is not ADR approved I am guessing by the two recovery pionts stick out front.
Where do we buy it mate ?
Hi Alex,You can just contact Drivetech 4x4 as they run RIVAL brand in Australia,
Yes ADR version of the bumper comes without these hooks but I think they will offer them as an option for using away from the roads.
How you finding ARB lift quality? is the ride stiff vs OEM? How much did you pay including installation?Got my ARB gear on.
OME lift kit. Legal rise of 50mm.
ARB Side Step/Rock rails.
Looking forward to being able to put a front bar and winch on soon (once it is out of development that is). Some photos below. First is after install and the other two are before.
Hi Alamein,How you finding ARB lift quality? is the ride stiff vs OEM? How much did you pay including installation?
I am looking to get a lift and ARB looks interesting.
Hoping these shots give a better perspective. The bar does wrap around the corner but does not join up with the rear guards. Note the additional black bracket below the tub which the mud flap assembly attaches to.Do you have a side shot? The area between the rear guards and bumper. I can't find any side shots so I'm assuming the bar doesn't wrap around the corner.
Yup, on the to do list.that's a shame, they could have done a little better job of that.
BTW, if your going to play offroad might want to think about moving the trailer plug. That spot does get a few hits. I just tuck mine up behind the bar when not needed.
Got my ARB gear on.
What happened with the reserve sensor and rear fog light with this installation?Finally, fitted it during the lockdown. ARB Rear bar with mud flap and plate relocation options.
The reverse sensors and fog lights removed from the original bar. Bar and recovery points bolt directly to the chassis rails with 4 bolts per side.
