dragoneggs
- Mark
- Dec 14, 2021
- Seabeck, WA
- '22 Snazzberry Pearl JLR
- Build Thread
- Link
Aux 3 and 4 are 15amp circuits if I’m not mistaken and Aux 1 and 2 are 40amps. If you are running the single ARB rated at 7.5amp under load, you should be fine. See the attached chart. Even if running at much higher psi, you should not fry your fuse.
https://m.media-amazon.com/images/I/51u7SodhO1L.pdf
The twin is 25amp under load. I went with the twin and hardwired it using the
Epic Kraken under seat mount but I think I could have used Aux 1 or 2. I just didn’t want to use up a switch for other uses such as lighting, etc.
