Anyone want to guess the 392 wheel backspacing; photo
Rob97RR
Rob
Northern 'burbs' Chicago, IL
22 392 XR Rubi, 2023 C8 Corvette Z06 & 2023 Ducati
Stay at home dad to 2 munchkins, best job in the world!
Hey all, how do I find the offset and backspacing of the stock (non-392) JLU Rubicon wheels? And is it still unknown what the stock 392 wheel's offset and backspacing is?
Also, I'm looking for a slightly wider overall stance, so if I end up going with 18x9's, and I want my new wheels & tires to stick out around an inch or two wider than stock on my 392, then do I increase, or decrease the amount of offset?
And do I do the same thing for backspacing as well?
Sorry for all the questions, still learning all this stuff. Thanks in advance.
BCMgunner
BCMgunner
Eli
392 on 37” KO2s
392 Backspacing is not known yet.
The lower the backspacing, the further out away from the axle the tires are pushed.
0II392II0
Kevin
Washington
JLURH
18's look good, though if your just starting to look into options, I would recommend 17's. From an off-road aspect the extra side wall is the given but tire availability is another. I've read in a few of the tire threads here of guys with buyer's remorse with their 18's. Becasue the limited availability and higher cost. If you want an 18 because you want an 18 disregarded this altogether. On my 4runner I wanted 18's and after some research I ended up with 17's and felt I made the right choice.
Rob97RR
Rob
Good info, thanks!
jeepken
Kenneth
Austin, TX
2021 JLUR 392
What do we know now that folks are swapping tires? I don't want to run spacers and I like these wheels. Still waiting to see how much other stuff we have to do to run 37's.
ValB
Val
Malibu CA.
Jeep Rubicon 392
Just ordered the Kenda 35.12.50 17R for my 392 , I thought I would try them out. I have had every tire in the world on my other jeeps and liked the 10 ply E rating top R speed rated @106 . Kenda had some good reviews, what the hell. Waiting for the Goodyear Territory MT 35-12.50 17r rated S 112, they release them soon. Going to try them on the stock wheels.
ShockerRacing
Chicago, IL
www.youtube.com
2022 Mojito! Wrangler 392, 2020 Neon Gladiator
The 37's worked perfectly with Method Race Wheels without any modifications. I am waiting for my 37" Nitto's to arrive so I can mount them on the stock wheels and see if there are any clearance issues.
Mac
MA
2020 Gladiator
Seems funny to buy the most expense Wrangler to date then put the cheapest tires out there on it.
AnnDee4444
'18 JLR 2.0
Want to comment on the thread title?
Cypher
J
AZ
Cybersecurity Leader
I assumed they would be running the same backspacing as the JT Mojave, it's a little less than other models, but not near as much as most aftermarket wheels. I can't imagine they would go any more than AEV as it would add to much to the scrub radius. so I guess I would say between the AEV and Mojave somewhere.
