Anyone using Rough Country Diff Skid Plate?
XtremeRetard
Richard
Rocky Mountains
JLURXR
These fitted great on my 3.6 etorque XR.
Front and back. No interference with anything.
They have been bashed quite a bit and I've jacked off on them quite a few times no problem.. Yet. (pun intended :) )
JMP
Jason
Little Rock AR
JLUR XR, M2
Pirate
Sorry… which skid fit your 3.6 etorque XR? The Rough Country, or the Asfir?
Same jeep. Struggling to find something that fits.
XtremeRetard
Richard
Rocky Mountains
JLURXR
Rough country. Still going strong. Almost daily abuse.
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? 20230217_160314
JMP
Jason
Little Rock AR
JLUR XR, M2
Pirate
Sweet. Ordered. Ready to go full retard too. Last trip, my naked pumpkin scared me a bit.
You have LCA skids on there? What kind on front? I have Artec for the back… still need to mount them.
Great pic!
XtremeRetard
Richard
Rocky Mountains
JLURXR
Rear LCA skids from RC as well. The bolt on ones. Engine and Trans skid from MORE. Those kind of cover most of the underside along with the factory stuff. Sure its not all flat and smooth, but it covers everything pretty well.
This pic shows more.
Jeep Wrangler JL Anyone using Rough Country Diff Skid Plate? 20230218_162730
blnewt
New Mexico
Just ask @cosine he knows!
Have had my F&R RC skids for a while now, been great thus far. Ended up getting an M220 rear end so had to modify my M200 skid, took a while but made it work. Post up pics when I get that skid back on there. They really are built to take abuse, and for the $100 price for each skid it's hard to beat!
MyDaughters20JL
WA
20 JL Sport S
SHIT! y'all got me second guessing my decision to sell my F&R R/C dif skids & rear LCA skid....thanks y'all ;)
Deleted member 64316
Guest
I also had to pull the front skid as it made contact with my oil pan/transmission skid plate support.
Which oil pan/transmission skid were you running that made contact with the front differential skid?
Fish
Darren
Southwest Michigan
2018 JLU, 2019 F150, 2023 Subaru Outback XT
Boat Sales
Still going strong? I was going to buy the Rusty’s or next venture one but for the price the RC diff skid is very tempting… I don’t have a single piece of RC on my jeep so I’m very hesitant lol
c20040215
Leon
The RC skid plates for JL are very solid. I have had mine for years and they have been great. The diff skid is less than 1/3 of the price compared to Next Venture.
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
I'm not a fan of differential skids as they reduce ground clearance, in the past I welded on 1/4" thick steel to my diff covers and never had any problems or loss of ground clearance.
This time I'm going for Currie thick nodular iron diff covers with recessed bolt holes, they will be my diff skids along with the iron center section that they bolt to. :)
https://www.currie4x4.com/currie-iron-differential-covers-wrangler-jl
I did buy the Rough Country steel winch plate and installed with my steel Rubicon front bumper. Website said made in China but they arrived and are made in USA now, I like it's mounting method/points better than most others and does not incorporate the two fangs that hang down from frame rails for the lower bumper skid plate to bolt to. I'm going to cut those two fangs off just below the swaybar bushing mounts.
Fish
Darren
Southwest Michigan
Boat Sales
I’ve smoked my diff cover a couple times on the bolt heads stopping my dead in my tracks. A skid will allow me to at least come to a slower stop instead of an abrupt slam.
XtremeRetard
Richard
Rocky Mountains
JLURXR
Yeah it was pretty solid. But I changed to a fusion axle, because the OEM axle sucked hard. But I would buy the RC skid again for sure. Its beefy.
WillysMeow
Corruptifornia
Bit wrassler
@XtremeRetard YOu had the M220 and M210 axles, correct? What sucked about them? What fusion axle did you go with? I bought Rusty's rear lower link/shock skids I'll look at his diff skid...always just bent some 2" wide 1/4" thick steel strap into half circle around proper size pole, then cut and welded right to the cover and filled in with some triangle etc peices to build my own guard with slight ramping on it.
XtremeRetard
Richard
Rocky Mountains
JLURXR
Basically just the locker. Sensor died, then locker failed to engage properly.
I was going larger tires, so before I totally trashed the OEM diff I sold it off and got a 14/60 Fusion 70" combo.
I run sticky baja boss x tires 40x13.5r17 and run 9 rated trails constantly.
