Watchtower02
Would love to hear feedback and see pictures!
You have a Sahara or already have 18 inch wheels? Almost everyone will recommend 17s over 18s as the tires available on an 18 inch wheel are significantly limited vs 17s and a lot are e rated, which are heavier and mainly for full size trucks. That being said if you already have the 18s and don’t want to swap wheels, the ridge grapplers are well spoken of on most forums and Facebook groups.Would love to hear feedback and see pictures!
Yes I have 18’s. Sounds like if I stick with my 18’s that the E rated ride will be stiffer? I’ve also read that the tire weight matters, And maybe more than the rating. This size tire I am looking at is 69 pounds. Thoughts?You have a Sahara or already have 18 inch wheels? Almost everyone will recommend 17s over 18s as the tires available on an 18 inch wheel are significantly limited vs 17s and a lot are e rated, which are heavier and mainly for full size trucks. That being said if you already have the 18s and don’t want to swap wheels, the ridge grapplers are well spoken of on most forums and Facebook groups.
Are you planning to run wheel spacers or offset wheels because tire will rub on control arms.Yes I have 18’s. Sounds like if I stick with my 18’s that the E rated ride will be stiffer? I’ve also read that the tire weight matters, And maybe more than the rating. This size tire I am looking at is 69 pounds. Thoughts?
Wheel spacers.Are you planning to run wheel spacers or offset wheels because tire will rub on control arms.
Can you post a picture please? I would love to see how the look..especially the width! Thanks!!I have 305/70r17 Ridge Grapplers that are E rated on my JLUR. They ride as well if not better than the KO2s once you find the right pressure which is about 32 psi for me.
Very cool and helpful. Do you notice any significant difference in ride quality or power? Any chance you could snap a picture from the front and back so I could see tire with later? That would be super helpfulOnly pic I have right now. A bit wider than stock, its right at the outside of the fender.
1.5" wheel spacers make it work without a lift. These are Nitto Ridge Grapplers. 295/70/18Would love to hear feedback and see pictures!
