Anyone running the Milestar Patagonia M/T tire?
UKCATS
DFW
2020 JLUR Recon/2020 Mazda3 Hatchback
I play piano in a whorehouse
I took them off at 6000 miles. I wouldn’t buy them again. No one reason why, just overall didn’t care for them.
UKCATS
DFW
UKCATS
DFW
Nice...I read that the 37" ridge grapplers are a good bit heavier at 82 lbs.(12lbs more than 37" Milestar) How much do you feel it accelerating and braking?
Yeah, Nittos are heavy, but I have confidence in them. I notice a little difference, physics don’t lie, but I had already re geared to 4.88, so acceleration is still good.
Bubba33
Saint Louis, MO
18 jeep wrangler Sahara JL
I'm taking mine off this week. I have rhe Patagonia at/r in 35s going on this week
alkapin
Alex
Vancouver, BC
2018 White JLUR, 2014 White GL350
Anyone running 38X13.50R17LT 119Q C/6 BW MILESTAR PATAGONIA M/T on the stock Rubicon wheels? Would the wheel width and backspacing be a proper fit?
Token
Toronto
2019 JLUR
No they would not.
A 13-1/2" tire on a 7-1/2" rim is FAR from ideal.
alkapin
Alex
Vancouver, BC
From this thread I see people run them anywhere from 24 to 32 psi on a highway. The stock Rubicon KO2s are set at 37 psi for highway. I was wondering what contributes to such big difference in the psi? Would such low highways psi make the Jeep unstable and too soft on a highway? Is that matter of the personal preference or the larger tires normally require lower pressure on a highway? Thanks.
hubbit
Corey
Chicago, IL
2018 JLU Sahara
Load range and ply count are the main factors. The Milestars have a higher load rating so they are very stiff compared to stock tires (normally). They are also heavier as a result. To offset the stiffness, you run a lower psi.
Believe it or not, there really isn’t a noticeable difference in stability at the lower psi. From my experience, when these things are aired up to 37+ psi, they ride like bowling balls on the highway. They even have the same crown shape from being overinflated and seem downright dangerous, in my opinion.
I’m sure there are people here who can give a more technical response, but that’s my experience and understanding.
alkapin
Alex
Vancouver, BC
Thank you for explanation. I guess sidewall stiffness would be one of the main factors here.
RubenZ
RubenZ
Ruben
Deep South Texas
myjlproject.com
2021 Ford F-250, 18’ Toyota 4Runner
I'm still waiting to see what the Norm is with these tires as far as longevity. If they wear down to SLICKS at 20k that's a no go for me. I'd be replacing them every 1.5yrs. Screw that noise.
I think I'm either going Cooper STT Pro or Nitto Ridge Grapplers next. Although honestly the KO2's are serving just fine for what I use my jeep for.
