Jammer
37x12.50R17 Cooper SST Pro, with 1.75" spidertrax what lift did you do that
what size lift do you have on your jeep ?Pics as requested. My driveway is a slope if the side picture looks wierd. Camera doesn't pick that up well.
on my cell hard to see up close. dont you feel like it lifted it more close to 3 like everyone else is saying ? I was going to do a spacer 2 lift but it doesn't seem as high as the Mopar lift. i test drove one 35s and felt real soft and bouncy when i took off and stop at the light. does your feel that way at all or close to stock or better then stock ?It’s the mopar 2 inch lift. Can tell by the shocks
They won’t rub if you adjust the steering stops.I guess without the spacers up front they were rubbing?
If you adjust steering stops don’t you lose turning radius?They won’t rub if you adjust the steering stops.
Yes. But Jeep widened these Rubi axles, resulting in a much improved turning radius VS the JK. The amount you will adjust them, you won’t even notice.If you adjust steering stops don’t you lose turning radius?
Kevin,I have them with 1.5” spacers
Went with exactly the same setup with mopar lift. Thank you37x12.50R17 Cooper SST Pro, with 1.75" spidertrax wheel spacers.
What's your Jeep's height?Went with exactly the same setup with mopar lift. Thank you
77 inches tall.What's your Jeep's height?
Any chance you have done a full compression test to see if you get any rubbing?Went with exactly the same setup with mopar lift. Thank you
Haven’t had a chance but once I do. I’ll let you know. The guy at the dealership flexed it after the install and said no rubbing but I can’t confirm it was full compression.Any chance you have done a full compression test to see if you get any rubbing?
