Anyone running 37s on stock Rubicon wheels?
spenat
nat
manhattan beach
2019 sting grey JLUR
Ran 12 psi for the last 3 days on the Rubicon without an issue. Only an idiot would think it's an actual beadlock running a 13.50" on a 7.5" wheel, and run low single digit psi. Having run a 14.50 pitbull on a 10" wide wheel and a 12.50 or 13.50 on a narrow factory wheel through the same trails, I can guarantee you from personal experience that the wider wheel will lead to burping air when a rock pushes against the sidewall 100% of the time. Burping air leads to further lowering of the pressure in the tire and eventually de-beading if you don't stop to add air. This is both logic and experience based. Obviously a wide double beadlock will retain the beads at much lower psi than any other setup. Conversely, if you are going to run a non-beadlock wheel, I guarantee a narrower wheel will hold a bead and/or air pressure better than a wide wheel every time. Full force against the sidewall pushing in to an obstacle, and even at 12 psi the tires didn't burp, let alone debead an a 38x13.50 tire on factory wheels. Take the same tire on a 9.5-10" wide wheel in the same condition and see what happens? Been there done that. The 13.50 would flatten out to 20" wide at 12 psi under full load coming down an obstacle, but keep telling me it doesn't work. If you want to spend 2500 on beadlocks, you better significantly outperform my stock junk. Meanwhile we just ran the entire Rubicon trail alone. 0 winching. 0 spotting. Used the front locker 3 times and both lockers once. The only optional obstacle we didn't run was soup bowl as it is far too early into the trail coming in from loon lake to push it when wheeling alone in the wife's daily driver. Keep telling me what you've heard and I'll keep doing what I've done for 25 years thanks.
great looking rig
whats your setup? ie spacers? lift etc.
DMentdJL
Az Desert
2022 JL Wrangler Rubicon
Pics as requested. My driveway is a slope if the side picture looks wierd. Camera doesn't pick that up well.
What tire and size?
DMentdJL
Az Desert
Thanks for the tips. I just installed 37’s last week and I’m very happy with the choice !
Although it does seem to downshift ever so slightly sooner up steep hills , It rides great.
I put a 5/16” 5x5 spacer behind the spare which bumped it out perfectly to clear the 3rd brake light AND my Tereflex hi-lift jack mount. No spare lift kit necessary.
Can’t wait to take it back to Moab to feel the difference from my (not-so) old 35s !
What is your suspension set up?
DMentdJL
Az Desert
Those of you with Rubicons, are you or did you have to run spacers with your lifts? AEV’s tech data say with Rubicon’s wider axels you can run stock wheels with their lifts? T/F? Can that be achieved with other lifts also?
greige
Robert
2023 farout
Anyone know where to buy and install 37s on factory rubicon wheels? I am pretty sure 4wheelparts will do it, but their prices are not too competitive. I do not have the means to get the tires online and bring them to a tire shop, so I am at the mercy of the tire shop on what kind of deal they want to offer.
Thanks
Zandcwhite
Zach
Patterson, ca
2019 jlur
Thanks
Why not? I fit 39s in the Jeep with the back seat folded down to get them to the tire shop.
Redcanyon77
Yorktown, VA
2023 JL Rubicon FarOut Edition, diesel
Here’s with 37” BFG’s and 4.5 MC. The wheels are actually takeoffs from a Gladiator Mojave with 1.75” spacers. I’ll eventually upgrade to something different but was trying to save a few bucks and got these for free.
Jeep Wrangler JL Anyone running 37s on stock Rubicon wheels? IMG_2651
Toycrusher
JLUR
Thanks
Discount tire mounted mine 🤷‍♂️
