Anyone replace the bulky electric sway bar disco with a manual setup?
Gorilla57
Chandler AZ
2019 JLUR Mojito
I've got a Genright Ultra Clearance bumper and was able to flip the electric one up. I had to notch out a few spots on the winch mount, but it really wasn't that bad. A member on here did it before I did and he sent me some pics. I may eventually do the Evo manual setup since I run down dirt roads faster than the 28mph the Tazer allows me to disconnected and it reconnects the swaybar.
Roky
Roky
Central Florida
If you do swaykill on tazer and remap the sway bar switch to the resume switch you will stay unhooked no matter what speed, stays disconnected until you hit switch again.
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
Hijack apologies; What happened to your rear bumper that caused you to trash it?
Thank you.
Following ....
Sourdoug is not a fan of single post swing away tire carriers... I have been lucky with mine from EAG... however I reinforced mine .. it is actually carrying a 40 inch tire with beadlocks... quite heavy at 139 pounds...
unsavory
Jimmy
2019 JLUR
Could you provide more details on this? What is a resume switch, and what would the operation of the disconnect be in this configuration?
Not sure I'm following.
Jeepnutz
Jeepnutz
Don
Southern Oregon
Chevy Silverado 3500
Good to hear. Do you recall how heavy the Genright steel winch mount and aluminum bumper were?
Jeepnutz
Jeepnutz
Don
Southern Oregon
Very interesting. I will have to check that out on my dads Tazer.
Roky
Roky
Central Florida
Yeah......the tazer allows you to remap some buttons for quick access. I use the resume button for my sway bar disco. It’s awesome, will stay disconnected no matter how fast you go.
Here’s from user guide.......
Button Remap: This function allows
the assignment of “hotkeys” for
quick access to some of the Tazer’s functions. The cruise +/-/RES may be used for this function. While the dash
is in Audio mode, press and hold the RIGHT arrow and press the button you’d like to remap. The choices are: 12
Any of the 8 light shows backup cameras
Line Lock
Rock Crawl
TC Kill
Cooldown Front/Rear/Front+Rear Lockers SwayKill
Keep in mind that not all functions pertain to all vehicles. These remap buttons will only program and operate while Cruise Control is OFF. When
Cruise is on, they will operate as normal cruise control buttons. For TC Kill, a vehicle restart is required to bring the system back to normal. For Lockers, the normal Locker off button disengages the lockers.
• Partial Reboot: Press left arrow and cruise RES with the ignition set to RUN and engine is not running, and the Tazer will reset several systems including the PCM (engine adaptives), RF Hub, Instrument cluster, ABS, BCM.
unsavory
Jimmy
2019 JLUR
Line Lock
Rock Crawl
TC Kill
Gotcha, thanks for the explanation! Do you know if the swaybar can be disconnected while still moving using this method? Or do you have to be completely stopped?
Jeepnutz
Jeepnutz
Don
Southern Oregon
Thank you.
The weight of the 37" Toyo on the carrier was causing the bumper to sag so bad that the spare was six inches away from the tailgate bump stops. My wife could push on the spare and flex the entire bumper. Was crazy how bad the bumper twisted with the carrier open and you had to lift up on the spare about 2 1/2 inches to get it to latch. Just a piss poor design.
Roky
Roky
Central Florida
You have to stopped to disconnect but it’ll reconnect while moving. I just do it as soon as I get to the trail head, then reconnect while airing up or just before pavement.
Jeepnutz
Jeepnutz
Don
Southern Oregon
Line Lock
Rock Crawl
TC Kill
Wonder if you can still use the offroad cruise control?
Gibson Leatherworks
