James Cole
Eyeing this one... any experience with this trackbar?
Thanks!
JC
Thanks!
JC
We haven’t installed one yet. Everyone seems to want the MC that comes with their lift or the steer smart oneEyeing this one... any experience with this trackbar?
Thanks!
JC
I have one, mainly chose it because it’s adjustable on the vehicle without removing it once installed. Plus, TeraFlex make some high-quality Componants, I love their stuff!! Fit and finish is always perfect!!Eyeing this one... any experience with this trackbar?
Thanks!
JC
Yes, this track bar was heavy duty, finished well and definitely high-quality.I have one, mainly chose it because it’s adjustable on the vehicle without removing it once installed. Plus, TeraFlex make some high-quality Componants, I love their stuff!! Fit and finish is always perfect!!
Installed yet? Thoughts?@NPE102414 @Chipe
The Teraflex track bar arrived the other day.
You guys aren't kidding..
Holy molly is this beefy.
I mean it doesn't look it, but damn that thing is solid and heavy.
And sexy too with forming and everything, can't wait to install it.
I have one and love it but I’m having clearance issues with my stabilizer because of the clamp bolts, also won’t work with the Synergy sector shaft brace because of the way it’s pointed at the bushing ends instead of rounded like almost every other track bar on the market. I’m replacing mine with the Steer Smarts track bar and I’m not happy about it because I really like the Teraflex track bar. Mine will be for sale as soon as Santa brings me my new track bar.Installed yet? Thoughts?
Really it’s hitting the falcon stabilizer? Won’t the steersmarts be more obtrusive with clamp bolt design they have? Where’s is it making contact with stabilizer?I have one and love it but I’m having clearance issues with my stabilizer because of the clamp bolts, also won’t work with the Synergy sector shaft brace because of the way it’s pointed at the bushing ends instead of rounded like almost every other track bar on the market. I’m replacing mine with the Steer Smarts track bar and I’m not happy about it because I really like the Teraflex track bar. Mine will be for sale as soon as Santa brings me my new track bar.
At full lock passenger it's way to close, and if I come down hard it will definitely hit it, hasn’t hit yet because I’m being really careful until I swap out track bars. It’s really close because of the Teraflex design, it’s really thick in that one spot whereas the Steer Smarts should clear it, hopefully!! But that’s only because I have it mounted through the track bar bracket and tie rod, when it was mounted in the factory location it wasn’t an issue. Only when I swapped out the tie rod and drag link it became a problem. And as far as the clamps go they’re are a non issue once you figure out the correct orientation of the clamps. Here’s a pic of how close the clamp bolts are to the SS at full lock. Even though I’m not a fan of those huge clamps I wouldn’t change the Steer Smarts parts our for any other parts on the market, they’re really that good.Really it’s hitting the falcon stabilizer? Won’t the steersmarts be more obtrusive with clamp bolt design they have? Where’s is it making contact with stabilizer?
How much lift are you running? I have the same stabilizer set up and my teraflex TB will arrive today, will it help if you rotate Stabilizer forward a bit on tie rod so you have more clearance? Thanks.At full lock passenger it's way to close, and if I come down hard it will definitely hit it, hasn’t hit yet because I’m being really careful until I swap out track bars. It’s really close because of the Teraflex design, it’s really thick in that one spot whereas the Steer Smarts should clear it, hopefully!! But that’s only because I have it mounted through the track bar bracket and tie rod, when it was mounted in the factory location it wasn’t an issue. Only when I swapped out the tie rod and drag link it became a problem. And as far as the clamps go they’re are a non issue once you figure out the correct orientation of the clamps. Here’s a pic of how close the clamp bolts are to the SS at full lock. Even though I’m not a fan of those huge clamps I wouldn’t change the Steer Smarts parts our for any other parts on the market, they’re really that good.
I have the Mopar lift and netted 3.5” when all was said and done. I spent so much time rotating and adjusting this thing but it’s just to damn close. But I also have the Synergy sector shaft brace and the Teraflex doesn’t play nice with that either. It’s a shame because I really like the track bar but given that everything is in such close proximity to one another all parts have to play well with one another. Because the Teraflex can accommodate up to 6” of lift the differential clearance bend is way to close to my sector shaft brace at mild compression. I have to over do bump stop spacing in order to clear the brace. So at the end of the day it’s just not worth it anymore. I absolutely love Teraflex so I’m not happy about it, but oh well. You can how tight it is.How much lift are you running? I have the same stabilizer set up and my teraflex TB will arrive today, will it help if you rotate Stabilizer forward a bit on tie rod so you have more clearance? Thanks.
You can rotate enough to maybe clear it but it’s really cocked on the track bar bolt. The rubber boot gets really squished and will end up ripping if driven that way. It doesn’t work for me but may work for you, every Jeep is different.How much lift are you running? I have the same stabilizer set up and my teraflex TB will arrive today, will it help if you rotate Stabilizer forward a bit on tie rod so you have more clearance? Thanks.
