migyb
- Miguel
- Feb 10, 2020
- Vancouver, BC
- 2020 JLU Willys
I am just seeing this now, and wow that’s amazing. Still torn on what to do with suspension! Should be making a decision soonDefinitely a big difference between spacer and full on lift. A full on lift will also vary between companies, some companies put a little more love in there because they figure it might be a hard top with steel bumpers and a winch so the guy using that same lift on a soft top stock will get more lift.
A spacer lift is exactly what it claims.
The RC lift wasn't bad, it is what it is... $180 and you will get 2.5" of lift in the front and 2" in the rear. They give you extended sway bar links and also brackets to extend your shocks. It rides like stock because you are using all stock components. We then removed the shocks and extension brackets and ran the Rancho RX5000 shocks for a year. We didn't like it, it's a stiff shock that after a year really started to feel like crap. With that setup we ran as hard as we could with the stock axles and open diffs out in Moab and Ouray.
https://www.jlwranglerforums.com/forum/threads/our-trip-out-west-with-open-diffs.34306/
Then we trashed the rear axle off roading and upgraded to D44s with lockers for next to nothing.
https://www.jlwranglerforums.com/fo...t-your-poorly-designed-diff-drain-bolt.37030/
We now have completely redone the Jeep and are running a 3.5" Teraflex ST3 lift with Falcon 3.1 shocks, Steer Smarts draglink and tie rod, Falcon 2.1 stabalizer and a Teraflex trackbar, sitting on 37" Patagonias. Just a little bit tweaked over stock
It'll be up on blocks in about 45 mins since the Mrs. wants her beadlock rings painted hot pink... lol.
If you have any questions feel free to PM for my cell number and we can chat. I enjoy helping others figure out what they want to do and sharing what I've learned. I just helped a guy from GA figure out what he wants to do and he was going through similar thing that you are.
