Anyone have experience needing to utilize a mismatched spare
jerrygcoffey
Jeramiah
Denver, CO
2018 JLU Sport 2.0T w/ eTorque
Software Engineer
I just installed a set of K02 T/As to replace my Milestar MTs. I kept the Milestar spare and also an additional one that had some decent tread left. I'm curious about the impact on the Jeep of driving on a mismatched spare should the time come. My logic was to keep an additional Milestar so I could put them both on if needed, although the tread wear is quite different.
Thoughts?
kah.mun.rah
Merenkahre Jr.
Duat
Are the heights the same? If so, not a big deal if the tread is difference between getting the flat and the tire shop.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Assuming they are different diameters.
If your differential is unlocked then it is made to differentiate between the tires rolling at different rpm. If the differential is locked it will cause additional wear on the tire and should be avoided for the long term, but will be fine to get you off the trail, especially if the trail is dirt and more forgiving.
lindaspins
Linda
Burton, OH
2015 JKU Rubicon Hard Rock
I have a mismatched spare-bought used while on a wheeling trip, for emergency use only. If I swap it out, it's to get me home and it will be replaced then.
Valpo Jeep
Doug
Valparaiso IN
15 Mas Ghibli, 18 JLU, 05 Gulfstream RV
As others have said, diameter / circumference is key for a spare. For a temporary and in 2WD should be more forgiving if the diameter / circumference is slightly off. Differentials can handle a slight variation easily, when you turn a corner all 4 wheels will travel a different distance based on the turning radius that wheel sees.
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
that's how differentials are made to work. cars have space-saver spares (smaller than the stock tire) and nothing happens.
roaniecowpony
Retired Engineer
Around southern California, I see old beat to death pickups with lawnmowers in the bed and 4 different sized tires all the time. ... and patches and plugs in the edge of the tread too. ;) ?
bjm00se
JLUR 6sp ordered 11/3/21, picked up 8/30/22
if they're the same diam and just different tread pattern and wear, don't even give it a second thought using it as a spare until you can purchase a matched replacement; however long a trip and number of days that ends up being
