Anyone flash Aux switches using Tazer JL?
jnunes22
Jack
San Antonio
2018 Jeep Wrangler Unlimited JL Rubicon
I Had company install aux switches, and a 10 inch light bar, they said they used AUX 1 (w 25 amp fuse), got it flashed and still didn't work.
**Update: Looking at a video online for installation, I see where tech wired wrong under passenger compartment, wired orange wire to male connector verses the female side. Also broke my side panel, its now 2 pieces instead of 1.
YarGib
Ray
Connecticut
2018 JLUR Granite Crystal, 18 Challenger, 96 Corvette
I installed the aux switches today. I programmed using the Tazer JL. The aux switches show up on uconnect screen. They don't work. No 12 V when turned on and no lights on switches. I double checked all wiring. Anybody have any ideas?
Alf1096
Kody
JLUR
Following as I didn’t know Tazer could do this. It would be well worth the price.
Bril
Bill
Round Rock, TX
2018 Jeep JLU Rubicon
Did you ever figure out your issue. I'm having the exact same issue. I've triple checked everything with a meter. Enabled the Aux switches with the Tazer multiple times and while the aux settings show up in Uconnect the switches don't light up. I confirmed I had good power and ground to the Aux switch panel.
YarGib
Ray
Connecticut
I'm flying back from a 2 week vacation now. I plan on having the dealer flash it when I get a chance. I know my wiring is correct also. Electronics and wiring is what I do for a living for the past 28 years.
Sting_NC_USA
Michael
Greensboro, NC
I installed mine last weekend, and everything is working fine. Enabled the AUX screen with the TazerJL, too. Each AUX switch was tested to provide 12V+ to each of the 4 AUX wires.
A few things to check:
  • First, are you all sure you have the new female orange wire going all the way into the Jeep's harness, such that it's firmly locked in place?
  • Was the Red shield on the Jeep's harness put back in place? Not doing so would likely cause some pins to not make good connections.
  • Also, are you sure the female orange wire you removed from the Jeep's stock harness is installed into the supplied two-slot connector plug (using slot #1), ensuring the male orange wire that came with the kit is exactly on the opposite side of that new connector plug's slot #1?
  • When you placed each of the wires into the harness that plugs directly into the AUX switch housing, did you press the white section of the plug in until it clicked? This locks the wires in place, and not doing so would cause the wires to not seat properly.
If all of the above has been validated to ensure each installation step was performed correctly (directions provided simply weren't the best), make sure you check all of the new harness' fuses and relays. If you have specific questions, I'll do my best to answer them based on what I encountered while installing the switches.
YarGib
Ray
Connecticut
Yes all that was done. Checked connector that plugs into Aux switch. Red has 12v black checks good to ground. Orange has 12 v which I'm guessing is how uconnect talks to switch.
Sting_NC_USA
Michael
Greensboro, NC
Yeah, the orange seems to intercept the stock UConnect signal and routes it to the switch and back. I know you've got electronics experience, I'm just trying to figure where potential gaps might be. If you're getting a 12V signal at the front and back of the new 2-pronged switch you installed and at the AUX switch itself, my best guess would be that there's a weak ground, or possibly a faulty relay.
I had a tough time with the colors of the wires going into the connector behind the AUX Switch. I'm slightly color challenged and wear bifocals, so dark wires in a relative dark environment took me a minute. Checking the colors of those wires may also be worth a look. Hope you get it figured out!
YarGib
Ray
Connecticut
Thanks for trying to help. I had some co-workers double check my work. I am human and have made mistakes before. Everything is correct. Some other people had problems getting the aux switches to work with Tazer.
Sting_NC_USA
Michael
Greensboro, NC
Anytime, glad to do it.
vavaroutsos
Pete
Scotts Valley, CA
I'm pretty sure if you see the switch setup under settings on the Uconnect, then the Tazer did it's job. I would check all the fuses in the aux switch harness, especially the one near the battery plus terminal.
YarGib
Ray
Connecticut
Went to dealer today to have steering recalibration TSB flashed. They flashed my Aux Switches while I was there. It's all working now. There is an update to Tazer that is suppose to fix Aux Switches.
RocketScientist
Tom
Massachusetts
2018 JL Sahara
I can confirm:
11.0.3 (and possibly lower) does not correctly enable AUX switches. They show up in Uconnect, but they don’t work.
I got my Tazer JL right before update, so it was not current.
I had to update to 11.0.6, reconnect, set AUX to “NO”, reboot, get back in, set AUX to “YES”, reboot. All is well now.
I was frustrated as I was fairly confident in my install, as OP was. But I rechecked everything, anyway, all looked good. Had to be something else. Thankfully we have this forum! Wasn’t looking forward to dropping $100+ at dealer to sort out!
Bril
Bill
Round Rock, TX
I can confirm:
This is exactly why I love forums. I downloaded the latest Tazer firmware and enabled the Aux switches and they now work perfectly.
Mvp8500
2018 Jeep JL Sport S
I can confirm:
Hey guys, sorry to beat a dead horse but I am stuck also. Installed the harness this weekend using both the video guide from DJ pony parts and the instructions and no lights. I figured I would give it a day to do more research and so today I took everything apart again and retraced my steps.
I checked all the fuses on the relay.
Set aux switches to no and reboot with tazer.
Set aux switches to yes and then rebooted.
Checked the ground to make sure it is grounded.
Checked Orange wire, good, fully seated.
Retraced each pin behind switch panel.
Still no juice.
Are there any fuses in the fuse panel I should check?
I am totally stuck.
Clayton Offroad
