texastonka
XD60 at 72”? 5” BS wheel?Current status.
What is outside to outside measurements from OS tire to OS tire? Looking for new trailer and need width info for that. Thanks.
There has got to be a way. We’ve broken into the canbus for so many other things.It cannot be wired into the factory canbus system. I just installed the prorock 44 frontvand have to wire to a switch. The factory is a canbus system. I’ve spoken to engineers at FCA and it’s not a thing
72.5" axles. 4.5" back spacing. 6.5" front spacing. 85.5" outside to outside plus tire bulge.XD60 at 72”? 5” BS wheel?
We'll get it taken care of.There has got to be a way. We’ve broken into the canbus for so many other things.
Just will take someone much smarter than me and possibly an engineer at FCA to take a few bucks under the table.
Need more info on the wheels. 11” wide sounds awesome.72.5" axles. 4.5" back spacing. 6.5" front spacing. 85.5" outside to outside plus tire bulge.
They're my wheels. They are 10" wide bead seat but 11" wide over all.Need more info on the wheels. 11” wide sounds awesome.
Nice! That's how I'd love to have a set of Forged Trail Ready beadlocks with rock rings made.They're my wheels. They are 10" wide bead seat but 11" wide over all.
I've been reading your posts on the Ultimate 60 upgrade, and am particularly concerned about my overall width to get it in my garage (94" opening".72.5" axles. 4.5" back spacing. 6.5" front spacing. 85.5" outside to outside plus tire bulge.
Thank you!9" wide wheels will change the bulge amount a bit. I'm 1-3/8" max with 10".
Andy, we're almost done with our build. We put in the Ultimate 60s and are using a Tazer J Mini, which I think is what you're using. Did you have to do something to turn off the Service 4x4 System light on Instrument panel?9" wide wheels will change the bulge amount a bit. I'm 1-3/8" max with 10".
This is what we've done so far....
Thanks
- We made sure 11.01 was the current updated Firmware in Tazer
- Set Locker to Both-is this correct position to remove the factory E Lockers?
- Set Front Axle Disconnect to Yes-is this the correct setting?
- There is another Menu item after that for DTCM, what is this and does it need to be changed?
Loren
I'm not helping unless you post pics.Andy, we're almost done with our build. We put in the Ultimate 60s and are using a Tazer J Mini, which I think is what you're using. Did you have to do something to turn off the Service 4x4 System light on Instrument panel?
Thanks
Loren
