Anybody running Ultimate Dana 60's yet?
Status
Not open for further replies.
texastonka
Kurt
Jeep Trackhawk, AEV Prospector XL, Viper TA2.0, Dodge Demon, etc etc etc...
Current status.
XD60 at 72”? 5” BS wheel?
What is outside to outside measurements from OS tire to OS tire? Looking for new trailer and need width info for that. Thanks.
texastonka
Kurt
It cannot be wired into the factory canbus system. I just installed the prorock 44 frontvand have to wire to a switch. The factory is a canbus system. I’ve spoken to engineers at FCA and it’s not a thing
There has got to be a way. We’ve broken into the canbus for so many other things.
Just will take someone much smarter than me and possibly an engineer at FCA to take a few bucks under the table.
DOOKEY
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
72.5" axles. 4.5" back spacing. 6.5" front spacing. 85.5" outside to outside plus tire bulge.
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
We'll get it taken care of.
texastonka
Kurt
Need more info on the wheels. 11” wide sounds awesome.
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
texastonka
Kurt
They're my wheels. They are 10" wide bead seat but 11" wide over all.
Nice! That's how I'd love to have a set of Forged Trail Ready beadlocks with rock rings made.
Lorenc
Loren
Palm Desert
2019 JL Rubicon
I've been reading your posts on the Ultimate 60 upgrade, and am particularly concerned about my overall width to get it in my garage (94" opening".
It looks like you have Toyo 40s, which I know bulge out a little more than the Nittos I'm doing (according to tire spec the Toyo is 14.4" and the Nitto is 13.58") Would you mind telling me what the overall width is with the bulge?
FYI, I'm planning on using 4" backspacing and 9" wheels with it.
Thanks so much!
Loren
Lorenc
Loren
Palm Desert
2019 JL Rubicon
9" wide wheels will change the bulge amount a bit. I'm 1-3/8" max with 10".
Andy, we're almost done with our build. We put in the Ultimate 60s and are using a Tazer J Mini, which I think is what you're using. Did you have to do something to turn off the Service 4x4 System light on Instrument panel?
This is what we've done so far....
  • We made sure 11.01 was the current updated Firmware in Tazer
  • Set Locker to Both-is this correct position to remove the factory E Lockers?
  • Set Front Axle Disconnect to Yes-is this the correct setting?
  • There is another Menu item after that for DTCM, what is this and does it need to be changed?
Thanks
Loren
5280Sapper
Michael
Saratoga Springs, Utah
2018 JLU Rubicon
Disabled Veteran
Factory lockers off. Factory axle disconnect off, change gear ratio and tire size .. should work after that
Thanks
Loren
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
Thanks
Loren
I'm not helping unless you post pics.
Status
