Anybody running Ultimate Dana 60's yet?
Status
Not open for further replies.
DOOKEY
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
Dude talks about it in the UD60 install video.
I will more than likely use the 10056733 harness. It seems to me that it's whole purpose is to take the factory connection and use it to trigger a relay to run the lockers. If the picture is accurate I'd just be sure to use a marine grade relay. It should be pretty simple to wire up and use the stock switches.
texastonka
Kurt
Jeep Trackhawk, AEV Prospector XL, Viper TA2.0, Dodge Demon, etc etc etc...
Agreed. Are you doing this soon? I am ordering axles next week. If you jump on this please let me know how it goes.
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
I'll start right after the axles get here. They were guessing the first week of February. Probably won't have the hydro assist setup yet. Still haven't figured out the rear tire carrier setup either. Should be able to get all the hard parts fitted though.
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
Are you going to try the Redneck ram for hydro steering. Seems like a real reasonably priced system that operates well with that big meat
Brett
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
I don't know yet. Sucks not having much info to go off of. PSC has a complete kit coming out mid January that I'm going to check up on.
I like the low speed power from the electric pump. Just not sure how long it will last with the redneck ram upgrade. Not sure anyone really does.
I'd like to go one direction once.
texastonka
Kurt
I've talked to more people than I can count about wiring up the Dynatrac elocker to the OEM switch. No one is saying squat, like it can't be done. I refuse to give in to that. Have you made any headway?
DOOKEY
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
I should have some free time this weekend to check into it. Won't be using the stock Eaton switch. Who would have ever thought a switch needed a safety?
Kevin8086
Kevin
2018 JLU Rubicon
It cannot be wired into the factory canbus system. I just installed the prorock 44 frontvand have to wire to a switch. The factory is a canbus system. I’ve spoken to engineers at FCA and it’s not a thing
Status
