Anybody install front Rokblokz on a MOAB or other model/trim with Mopar Performance Rock Rails?
bpdunsta
Chicagoland
2019 JLU Moab
Looking to get a set of front mud flaps to combat the slush and "stuff" kicking up and completely covering the doors. The Rokblokz look like winners, just not sure if the cutouts for the Rubicon accommodate the performance rock rails or not....or if cutouts are needed at all in my setup. Ordering/installing options are:
(1) order with cutouts and they install "as is"
(2) order with cutouts but the cutouts need to be modified to install properly
(3) order with no cutouts and they install "as is"
(4) order with no cutouts and have to make custom cutouts from scratch to install properly
I'm hoping somebody has experience I can leverage. Thanks in advance!
bpdunsta
bpdunsta
Chicagoland
2019 JLU Moab
For anybody following....#3 is not the answer. The performance rock rails come far enough forward that a cutout is needed. Hoping to exchange mine with no cutouts for the ones with the Rubicon cutouts and modify those. I don't feel up to making cutouts from scratch.
BLACKMOAB
2018 Black MOAB (a collectors item)
Did you get the front RokBlokz installed successfully on your MOAB and if so, which option did you use and how did the install go? Could you post pics or PM me some? Thanks
bpdunsta
bpdunsta
Chicagoland
2019 JLU Moab
I ordered the "uncut" version. I quickly realized that was not the best option (for me) so I contacted RokBlokz. Since I had already installed the metal clips, they could not refund/exchange, so they offered to send me a template I could use to make the Rubicon cutouts. I was able to use the cardboard template and modify it to account for the Performance Rock Rails. I scored the flap with a utility knife and then used a Dremel to complete the cutout.
Unfortunately, I was not able to get the flap to sit properly (likely user error), so I did not install them. I may give it another shot when it warms up a bit.
BLACKMOAB
I guess it’s just not possible to have mud flaps with the MOAB performance rock rails.
JerseyMark
NJ
2021 JLUR, 2019 JLUS
I know I am resurrecting an old thread, but wondering if you ended up getting the RokBloks to work. I just got a Rubicon and plan to add the performance rock rails. Originally I was going to get the Weathertech mud guards, but it says they wont work with the performance rails/moab rails.
bpdunsta
bpdunsta
Chicagoland
2019 JLU Moab
I did not get them to work. You say you have a Rubicon. Unless you swapped out the stock rock rails for the performance ones, you can get the RokBloks with the cutouts and they will fit just right.
JerseyMark
NJ
Yeah, I have a stock Rubicon, and I know the mud flaps would work(RokBloks or weathertech) but I was able to get a set of takeoff “Mopar Performance Rock Rails” which I plan to swap on to the Jeep. I need the small step for the kids to get in.
I might just order a set of them and use a dremel to cut out more
bpdunsta
bpdunsta
Chicagoland
2019 JLU Moab
I think that’s the best idea. Modifying a set with existing cutouts should be easier than a set without. Best of luck.
OMTBiker
Derek
Ohio
2021 JLUR White | 2021 JLU 80th Snazzberry
Information Technology
I have the RokBlokz with the cutout then modified to fit the performance rock rails. It can be done with a little patience, mine are slightly off but not too bad. I had concerns with the additional material being cut out and durability but I have not had an issue even on off-road trails.
JerseyMark
NJ
Thanks, those look great! Btw, nice JT - I love the Hydro Blue
JerseyMark
NJ
Thanks FrostQ, those look good. I like how it is uncut, less chance for dirt/salt to get through. How is the zip tie part on the inner hole holding up? Any issues with it loosening up, etc...?
JerseyMark
NJ
Just wanted to update the thread. I ended up using the weathertech rubicon mud guards. I used a multitool to cut them around the larger rock rails. It was a but of a pain and I cut a little too much off the first one, but overall, I think it turned out ok.
Shub_32
PA
21 Runicon
I’m in the same boat . I put the original rails back on for now but you’ve given me hope to reinstall my performance rails. Did you remove the end cap for a template since it’s impossible to use the rails installed ? Thanks
Dwayne Lane's Chrysler Jeep Dodge
