Anybody else's JLs doors do this?
Ntegtmeyer
Nathan
Aurora, IL
2018 Jeep Wrangler Sahara, 2014 Jeep Grand Cherokee Summit, 2014 Jeep Patriot Oscar Mike Edition, 2012 Jeep Compass Limited
My two front doors make a clicking/snap/pop noise whenever they are opened or closed. I have tried lubing the pins and door check with no luck. I currently do not have the bolts installed on the hinges but wouldn't think this would make a difference as I've done this for years on my JK without issues. Just wondering if anyone else has ran into this minor annoyance and if so what was your fix if you found one?
UNC Rubicon
Bret
Kernersville, NC
2019 Billet Silver JLUR
Are the bolts to the door checks tight? If they are loose, it could cause the check to move.
Rubi-Zero
Nashville, TN
JL Rubicon , Audi S5
the bolts are fine to leave out, I too have always done this, makes for removing the doors much faster.
I did have the click on the passenger door but after I slightly repositioned the door check and then tighten back down it’s gone.
You don’t have to totally back the bolt out just enough to move it and then tighten back down
Ntegtmeyer
Ntegtmeyer
Nathan
Aurora, IL
  • Thread starter
  • Thread Starter
  • #5
Ok thanks I’ll give this a try!
JIMBOX
JAMES
FERNLEY NV
2018 HELLAYELLA JLU SAHARA/2016 "STINGER YELLOW" RAM
I've noticed one (of the many) improvements of the JL over the JK and-
The doors are very stiff while opening and my '08 was so loose , I thought the door was gonna fly away-
I suppose as my JL gets "MORE USED" it'll loosen up!
W.E.
JIMBO
Rubi-Zero
Nashville, TN
W.E.
JIMBO
It’s because the JK did not have the door check like the JL’s do. So if you forget to hook the strap on the jk door after putting the doors back on, a lot of times they will swing open and the side mirrors will hit the side cowling in front of the windshield and dent it. It’s a nice feature for the JL to have.
Ict_JL
Wichita
Jeep JLU Rubicon
Fireman
Had my drivers door pop and crack. Took to dealer and they replaced the door stop. Warranty. Also I do not have door nuts on
Bearded_Dragon
FL
2018 Mojito! Rubicon
I didn't tighten the door stop enough once and it made the popping sound. Snugged it up and the noise has never occurred again.
Steamboat
Steven
Atlanta, GA
2018 JLUR, 2018 Volvo XC90
I had this with the door bolts removed. I believe if you look closely in the door jam, you will probably notice it is rubbing paint- at least it was for me.
SWIRVN
Ryan
St. Augustine, FL
JLU Rubicon (ordered)
My drivers door is popping/clicking when I open and close it. I’ve tried loosening/ tightening both hinge bolts, door check bolt and the two nuts on the door side with no luck to getting it to stop.
Any other ideas outside of door check replacement?
Just trying to avoid making a trip to the dealer.
Jarod129
Cocoa Florida
2018 Wrangler JKU
Mine has been popping / clicking for a couple months now. When it first started making the noise, I isolated it to the door limiting stop. I sprayed some LPS NO.1 lubricant where the door stop goes into the door being I noticed a little grease in there. This stopped the noise, but it just started again which prompted me to search and see if anyone else has been having the same problem. On mine, when I put my finger on the door stop and open and close the door slowly, I can feel the popping / clicking. I sprayed it again with the LPS which did nothing this time. I sprayed lithium grease in there which didn't help either. All the hardware is tight. I guess I'll either be taking the door apart myself and looking at it, or just taking it to the dealer to have the door stop replaced. Only my driver side door is making the noise. It pops / clicks about three separate times when opening and closing the door and its fairly loud. The Jeep has 6500 miles on it.
PastoreJesse
Jesse
Connecticut
2018 Jeep Wrangler JL
My door is also making this popping/clicking sound as well. I’ve taken it to the dealer and they replaced the door check, but the noise hasn’t stopped. The next step they recommended was to replace the sheet metal where the door check connects, but I feel like this may be a little extreme to stop the sound...
Anyone have any ideas as to alternate options before taking that step? I’m just worried that they’ll end up doing more harm than good.
White2019Rubicon
Christopher
Palatine
2019 JLU Rubicon
Hi I just got my 2019 JLU Rubicon and took off the front doors this weekend. Now the drivers door is ticking as well, seems like once on open and once upon close. Has anyone figure out why they are doing this?
Thank you
Allmoparparts.com
