Good morning people,
I was wondering if anyone has purchased the Fab Fours stubby bumper. I cant find any reviews on this. I really like the look and its alot cheaper than the oem rubi steel. Thanks in advance
It has a couple of different mounting options for foglights, i was able to hook up my inspired engineering fogs with no problemsAre you able to install factory fog lights? I see the cut out is square but I seen some pics with round lights behind...a
I just had mine Line-Xed. The power coating on it was rough at best.Good morning people,
it turned out really good! Can I ask what the coating cost?I just had mine Line-Xed. The power coating on it was rough at best.
It was $200 out the door for their top end Line-X Platinum that is suppose to be 300% stronger than their regular product, they also added their UV sealant. I am very happy with the results. I installed it last night along with a M.O.R.E. skid plate. The bumper install was fairly simple with the exception of the fog light bolts. I also would have liked to have been given torque specs. One thing to notice in the last pic is how close this bumper sits to the grill. It would have to be loosened to take off the grill.it turned out really good! Can I ask what the coating cost?
Yes, I installed my factory Rubi lights in it.Are you able to install factory fog lights? I see the cut out is square but I seen some pics with round lights behind...a
Just curious why you went with the M.O.R.E. skid plate instead of the Fab Fours sway bar cover?For the M.O.R.E. skid plate to work I had to cut to 1/2" notches 1/2" deep about 5" into the top of either side. I knew that I would have to modify it before I purchased it so it wasn't a big deal. I also touched up the stainless bolts that were showing with undercoating to give everything a uniform appearance.
I have used it previously and it is proven solid.Just curious why you went with the M.O.R.E. skid plate instead of the Fab Fours sway bar cover?
The Mountain Off Road sway bar skid is bulletproof. I can’t say the same of FabFours. I have previously used it and was very happy with it so I used it again.Just curious why you went with the M.O.R.E. skid plate instead of the Fab Fours sway bar cover?
