Hey Larry, as Steve said, and I can attest to, having done exactly what he says (i.e. buying it,) it's a set: meaning there's a good chance one of the torx bits in the set fits your need. : - )Thanks. I wouldn't know which on would fit
Thanks. I have torx set with the correct bit. However once applied to the ratchet it too thick to fit between the railsHey Larry, as Steve said, and I can attest to, having done exactly what he says (i.e. buying it,) it's a set: meaning there's a good chance one of the torx bits in the set fits your need. : - )
The socket end of a torx bit is 1/4" I believe, that being said you can put the bit in the screw and then use a 1/4" wrench to turn it. A pain, I know, but it will only take a few turns until you can use your fingers to turn it out. Why are you removing them?Thanks. I have torx set with the correct bit. However once applied to the ratchet it too thick to fit between the rails
Thanks. Unfortunately trying to tighten them. I have a bit of a rattle when the one touch is opened. Trying to save a trip to the dealer.The socket end of a torx bit is 1/4" I believe, that being said you can put the bit in the screw and then use a 1/4" wrench to turn it. A pain, I know, but it will only take a few turns until you can use your fingers to turn it out. Why are you removing them?
