Any engine with ESS
LawrenceR
Lawrence
Auburn Ca.
2020 Willys Sport
I have a question about the ESS system.
I want to start by saying, my father built engines for a living. He not only built them he blueprinted and balanced the motors. One thing he always preached was "...the most wear an engine gets is on start up, all of the oil is in the pan..." The next topic was, "...each time the engine is started, extra wear is put upon the starter motor, electrical systems, etc..."
The info supplied by Chrysler states "..The 3.6L Pentastar® V6 engine includes Engine Stop/Start (ESS) Technology. ESS automatically shuts the engine off at full stops, then re-engages for takeoff. The technology is engineered to help deliver efficient performance, and can be disabled with the push of a button. I can't see why the above would not also apply to the 4 cyl and the diesel.
Is this happening at every time the vehicle stops ? Like every time at a stop light or stop sign ? OR if we are sitting talking to a friend while on the trail or pause to pick up the mail ? Is there a pause delay, after so many seconds, is when the engine turns off ?
I am curious how many times during the course of a normal drive is the engine actually shutting off.
Additionally, the information supplied states the driver can disable this function. How is this working in the real world ?
To me, it seems that Chrysler spent a lot of time and money paying some engineer to come up with a way to "promote" a system most of us will never use - not to mention the extra wear our engines are getting.
Paluss
maryland
2022 JLURD
Start stop technology is used by just about every car manufacturer and has proved to be a reliable system and does improve gas mileage. You dad was correct about engine wear, but I would add that it is the "cold" start that has the biggest impact. On the start stop the engine is still hot and the oil is still in the critical areas when the restart happens. Also the bearings inside the motor have been upgraded to handle one 300,000 starts and the started was designed to handle the wear and tear. For most ppl it takes time to get use to the start/stop and then its not an issue for others the press the button to disabled which have to do each time you start the engine, I believe it is automatically disabled when you are in 4wd lo etc when you are on the trail...
Jitzy
Orlando, Florida
2020 JLU Willys
Retired Police, Now Certified Custom Club Fitter
Chrysler didn’t start this EVERY new car out for the last few years has this and yes it is the most annoying thing possible but turning it off is simple.
JPAloha
Calgary
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE
Accredited Financial Planner
I don’t love it but I don’t hate it either. It only kicks in when the engine is warmed up and only while the vehicle is in gear with the brake depressed and at a full stop.
The button to turn it off is easily accessible and simple to use plus I have the Tazer Mini which could disable it altogether. As my normal commute is mostly highway and a few stoplights it doesn’t play a big part in my day to day driving.
D60
CO
JL
I find it amusing the oil companies are now making oil badged as specifically being for start/stop applications.
Either it's all marketing or the vehicle manufacturers are lying when they say it doesn't contribute any wear to the engine. I think it's both personally.
But OP, this isn't a Chrysler thing, it's an every-manufacturer thing. Really it's a stop-gap bandaid until vehicles go all electric.
Use a battery powered weed eater or chain saw and you won't miss the idling in between cuts, or the "oh I forgot that ONE branch, gotta start it back up again."
I use my Tazer to disable my ESS. ESS has not been allowed to function for the 16k miles my JL has been driven thus far.
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
ESS is very annoying... it is only good for making our rigs more expensive... more complex... with more components to fail and I imagine few of us benefit from it... or care about it... I mean... our rigs are not fuel-efficient to begin with ... why bother installing ESS on a Jeep Wrangler? lipstick on a pig... ... it has to be politics and government regulations.. because it really makes no sense, most of us lift and install big tires on our rigs which horribly kills MPG ...... I, like many others have installed Tazer just to get rid of ESS... the only good ESS is a DISABLED ESS...
That being said... I think the engineering that goes into ESS is quite genius... there are other companies that make smoother versions of ESS... installed on cars where it really makes sense.. I wonder what real-world ESS data looks like during testing of stock JLs..
again... the only good ESS is a DISABLED ESS...
sardog12
Geaux Tigers!!
2004 Wrangler X-Gone, 2019 Wrangler Rubicon
IT
You should understand that this is not some gimmicky system that Chrysler is using to try to compete with other manufacturers. This is a response to government regulations that were enacted when this model was being planned.
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
@LawrenceR it's just a simple push of the ESS button to disable it. It's pretty much routine for me to push the "Start" button, then ESS off right after. They're practically right next to each other LOL. I never use it, and I've also wondered the same thing about wear/tear - mostly on the starter motor and electrical system. I have noticed no loss or gain in fuel economy to speak of either. Only certain powertrains have the ESS system available (it's not on the Hemi Charger, for example) it's just another way for the manufacturers to claim better fuel economy numbers for the EPA.
IdahoJOAT
Caldwell, ID
2021 JLURe Tuscadero, Black '05 Silverado
I've never had a vehicle with it, so it's interesting.
I've noticed that when you begin to let off the brake (at a stop sign or light) the engine fires right up. There's virtually no delay versus leaving the engine on.
We personally don't plan to lift or put bigger rubber on the JLUR, and it gets about the same mileage as our '14 Fusion.
jessedacri
Jesse
Los Angeles, CA
2019 Bright White 2dr JL Rubicon 3.6
I believe it currently is an emissions requirement (millions of cars with their engine stopped at red lights is a measurable benefit, for sure) and every manufacturer has this. It's less intrusive on the 2.0 where the motor itself was designed around this. It's basically a retrofit on the 3.6, where it fires a normal-sounding engine start sequence. The 2.0 comes back on smoothly like, well, a Prius. There are unfortunately millions of those on the road with ESS and hundreds of thousands of miles so there's definitely a way to do this out there without blowing up the motor long term.
You can disable it with some off the shelf products. It also will be automatically disabled if you're in any 4WD mode, or with the transmission shifter in manual gear selection in 2H, or if you have your seatbelt off. The ESS OFF button has to be pressed every time you power up the Jeep, otherwise.
I hate it, but I find it easily defeatable and it never, ever comes on out on the trail.
limeade
Guy
Reno, NV
Like @jessedacri stated, the 2.0 eTorque is very smooth and I leave mine on. The eTorque also has the Belt Start Generator (BSG) and a 48 volt battery pack and is not having the auxilliary battery problems like the 3.6's have. Beginning in 2020, the 2.0 eTorque is only available in the Recon models, all other models are available with the 2.0 with regular ESS.
I just did a test drive of a 2020 JLUR with the 2.0 ESS and didn't like it. The eTorque is much smoother and you hardly notice the start/stop function.
nerubi
Nebraska
2019 JLR, 2020 VW Tiguan
Without ESS, PHEV, full electric and other features you wouldn't be buying Wranglers much longer. Jeep has to meet MPG and emissions requirements and they don't have a lot if Corollas or Prius in their lineup to help.
FCA announced:
In its continuing efforts to monitor and reduce the environmental impact of its vehicles, FCA has completed its latest Global Warming Potential (GWP) analysis.
The redesigned-for-2018 Jeep® Wrangler Unlimited was compared with the previous-generation vehicle, its overall GWP is 15 percent lower than that of its predecessor.
So I know some of you, especially from Texas, love to bitch about technology but learn to live with it or go back to riding the ultimate 4 wheeler, a horse.
