The Great Grape Ape
- Mar 30, 2017
- Canadian Rockies
- 2015 JKU AspenX 5spd , 2015 JK Sport 6spd
Again, first and foremost, I don't think the Hemi is coming to the Wrangler, but certainly the barriers being mentioned aren't sufficient a reason. More just there isn't enough competitive pressure, so FCA is Lazy !!
It sells as much and sometimes more than the Grand Cherokee or almsot any other FCA product and it only had 1 engine for about a decade, while the GC had 6 !?! Yeah that's not logic, it's marketing and accounting BS !!
I do that with the Pentastar every year for Ski Race season (where noon temps are -36) and the Pentastar starts remotely like a charm every time (thanks also in part due to synthetic oil not straining the starter). What is stuck in the lot after the races... diesel, because even with winter fuel, their fuel filters freeze up and the glow plugs can't keep up, especially if they are older. And look at the CRD's GlowPlug warning saying they are not expect to work well bellow -25 even after 2 full cycles. With the EcoDiesel not having a pre-heater it's not going to fair better, and if your winter diesel freezes at its near -24 point then you're hooped, and if you use arctic/polar diesel which is common here, but not where most people come from to go skiing, then at about -41 to -43 you're not pushing crystal and wax through the filter or the system.
Regular gasoline is fine to below -60C, which I have experienced as a non-wind-chill calculated temperature with addional 130KPH winds on top of a ski hill when the Stratosphere popped down for a few hours. Now THAT'S FAQin Cold !!
We've had this discussion before an all you arguments apply to the bigger, heavier and more expensive diesel, except the HEMI market is already shown to command a big premium, I'm still doubtful Jeepers will pay the usual $4K premium for the EcoDiesel let alone, likely a bigger bump (cause it caomes with the 700+NM transmission).Well guys, it's just not ever going to happen. There has never been a factory V8 in a Jeep Wrangler since they debuted in 1987, and there never will be. From an engineering standpoint, it's not necessary and it's too expensive. That's just all there is to it.
Again, same applies to diesel which is not getting any refresh research and relies on oly Tech (even the EcoDiesel is licenses Fiat tech).Not to mention that FCA overall has plans to drop Hemi V8 engines from vehicles across the board over the next 5-10 years.
CAFE is aided by MDS, as well as the Pentastar's E85, and if they were so focused on it, why even bother with a turbo4 vs the 2.4L 4cylinder, then put the 1.4Turbo in the Hybrid. Diesel used to be the Euro darling, but it's being legislsted out of existance, and it won't last here because it's still super niche. Hemi GC still outsells EcoDiesel by about 10+ to 1 and Pentastar like 3+:1 even when they were hard court press on EcoDiesel.CAFE standards are getting tighter, crash testing is getting more strict, and many people speculate that the combustion engine is a dying breed. I personally drive a V8 every single day right now, and most of the dozens of vehicles I've owned have had V8 engines. But when you're talking future mid-size 4x4s you can simply forget about fuel thirsty V8s...it ain't happnin'.
For the record, you obviously don't live or play in the cold.And for the record, I've owned two diesel Jeeps and neither of them "sucked in the cold".
0F, who the FAQ calls that cold for starting issues? I'm talking about unplugged in the back country or on a ski hill all day in temps around -40, THAT is cold.I plugged them up when the temp. went below 0°F and never had a single no-start issue.
