Chicago
That’s my original, it was built and scraped on 6/1Chicago is this your clone?
Chicago 1C4HJXFN0JW1***** 4 Rubicon 2.0L Turbo FOUND NOT FOUND 2/16/2018 6/21/2018 3:54:43 PM
I’m My Turbo now stuck in D 1 all over againThat’s my original, it was built and scraped on 6/1
BuildSheetServlet.pdfI’m My Turbo now stuck in D 1 all over again
I changed my Turbo Clone to the date it was cloned. your Clone showing your original order date...I’m My Turbo now stuck in D 1 all over again
I was in May , it was built and waiting in inspection around May 12 then it sat after firesDam, I thought we were getting somewhere...
Yes same date ,I believe FCA USES original date ,I changed my Turbo Clone to the date it was cloned. your Clone showing your original order date...
A bunch of Turbos were going to China according to member here that lives in China and I also believe Saudi Arabia.I did not even think that Jeep (since only the one plant complex) would have different models for different markets - . . . . I did not, however, find any countries where you could get the 2,0 . . . .
I believe the water fording line is the same as all other engine and drivetrain combinations.Okay...here is a question. Do you think the Turbo's BSG will be prone to issues if traversing water areas? Is the BSG battery protected?
Crypto CounterYep... posting here so we can look back later to confirm numbers if needed.
Crypto Counter
6/21 at 12:21 PM EST:
4 Door Turbo
54/0
2 Door Turbo
14/4
when did u order yours , it’s good to know production has begun thoYes same date ,I believe FCA USES original date ,
