Antidote Outdoors
Rock Sponsor (Level 1)
Orange County, CA
www.antidoteoutdoors.com
Jeep Wrangler
Hello Fellow JEEPHEADS!
We have a sweet deal on Wrangler Platform Racks. NO DRILLING REQUIRED! Mounts directly to the drip rails! Designed for roof top tents! Link is below as well as a coupon code for $99 OFF Ralf Racks and $200 OFF Full Racks!!!
https://www.antidoteoutdoors.com/product-page/jeep-wrangler-roof-rack
For a limited time
For Half Racks it's $99 off for JLWRF use promocode "jlwrf1" at checkout
For Half Racks it's $200 off for JLWRF use promocode "jlwrf2" at checkout
If you have any questions or concerns feel free to DM me or call or txt 949.449.3831 call or txt between 10am-4pm PST
About the Jeep Wrangler Platform Racks:
The Wrangler roof racks are much more than just two crossbars. It is an entire roof rack platform that you can customize and set up for whatever your Jeep will need. No drilling is needed! It mounts directly by securely clamping to the drip rails along the sides of your Jeep (JK models also use the rear window brackets)
The crossbars are T-Slot and U-Bolt accessible for all of your mounting needs. Add a roof tent, cargo box, awning, gas/water cans, etc. The sky is the limit with the versatility of these racks!
We have two different lengths available for both the Jeep Wrangler JK and the newer Jeep Wrangler JL:
Half Rack Platform:
Dimensions: 5ft3in x 4ft7in
Rack weight: 58lbs
Adds approximately 3in of overall height to your Jeep
Recommended Maximum Dynamic Weight Limit: 175lbs
Max Static Weight Limit: 600lbs
Full Rack Platform:
Dimensions: 7ft3in x 4ft7in
Rack weight: 75lbs
Adds approximately 3in of overall height to your jeep
Recommended Maximum Dynamic Weight Limit: 225
Max Static Weight Limit 700
Features:
  • 9 to 12 Cross Bars with T-Slots with Rubber Gaskets
  • 6 to 8 Mounting Feet with Rubber Edgings to protect the Roof
  • Adds a total of +3 inches of clearance
    • Optional +5 inch Mounting Feet available
  • T-Slot extrusions along top, sides, and bottom of outer frame
  • Tools and Instructions included
Disclaimer: Manufacturers of Jeep do not recommend putting anything on the roof of your Jeep
Riperoo
Bucks County PA
2021 Jeep JLU Sahara Altitude Diesel
I know its a stretch, but do you know if this will work with the Bestop sunrider? The half rack obviously, but just wondering if you could fully open the sunrider with this installed? it appears from the pics you could shift it towards the back a bit to help clear if needed. Curious, looks like this might fill the bill for what i am looking for, hauling a couple of kayaks to the beach on occasion.
Lunchbox
DMV
Jeep Wrangler
Second for compatibility with the bestop sunrider. Looks like a great option if it’s compatible.
Schmack
Virginia
Sarge Green 2022 JLUXR
My Antidote half rack is sitting in my garage just waiting for me to have some time to install it.
@Antidote Outdoors Any plans to release a wind diffuser? If not I'm going to start looking for an alternative solution.
Beowulf
Jeep Wrangler Rubicon Unlimited
I hope it is so low profile that you can't even remove the freedom panels. With a full rack, any plan to go topless, or panelless is out the door. I want as low profile as possible for air flow and every mm of lower CG counts.
Of course with a support bracket on the freedom panel on the full rack, the removeability is gone.
Antidote Outdoors
Antidote Outdoors
Orange County, CA
Jeep Wrangler
I am not the expert on the bestop sunrider but it should work just fine since we have had many customers purchase the half rack who had the same top. Best thing to do is to use the measurements of the half rack against how your current roof space.
Antidote Outdoors
Antidote Outdoors
Orange County, CA
Jeep Wrangler
What kind of testing was done to come up with those weight ratings?
we have done extensive research over the years in many different forms and have reached these numbers based on safety ratings. The rack is capable of much more weight however the big concern is your fiberglass roof. In all the units we have sold luckily we have not had any issues due to the weight distribution of the mounts.
Antidote Outdoors
Antidote Outdoors
Orange County, CA
Jeep Wrangler
That's awesome to hear! check out our youtube video on how to install it for an easier time. ill drop the link below.
wind diffuser is in the works but may not be out until 2023
here is the jeep rack install video
Antidote Outdoors
Antidote Outdoors
Orange County, CA
Jeep Wrangler
the standard one is 3in taller than the tallest part of your jeep which is near the center.
ZCashio
Zach
Arkansas
2020 Jeep Wrangler Unlimited Rubicon
Self-employed
I’m in love with mine, possibly getting the RTT installed this afternoon.
jbcrane
Fort Collins, Colorado
'21.JLU.6MT.GCM.35.4.88.ZEON12
Technical/Indstrial 3D Animator
Half Rack Platform:
Rack weight: 58lbs
Features:
This looks great and just what I've been looking for. 3" overall is the big issue: will it allow me to pull my Mopar-lifted Wrangler into my 'standard' garage? That's the biggest question of all. Thanks for the pointer. Getting the tape measure out.
