- Jan 19, 2022
- Orange County, CA
- Website
- www.antidoteoutdoors.com
- Jeep Wrangler
Hello Fellow JEEPHEADS!
We have a sweet deal on Wrangler Platform Racks. NO DRILLING REQUIRED! Mounts directly to the drip rails! Designed for roof top tents! Link is below as well as a coupon code for $99 OFF Ralf Racks and $200 OFF Full Racks!!!
https://www.antidoteoutdoors.com/product-page/jeep-wrangler-roof-rack
For a limited time
For Half Racks it's $99 off for JLWRF use promocode "jlwrf1" at checkout
For Half Racks it's $200 off for JLWRF use promocode "jlwrf2" at checkout
If you have any questions or concerns feel free to DM me or call or txt 949.449.3831 call or txt between 10am-4pm PST
About the Jeep Wrangler Platform Racks:
The Wrangler roof racks are much more than just two crossbars. It is an entire roof rack platform that you can customize and set up for whatever your Jeep will need. No drilling is needed! It mounts directly by securely clamping to the drip rails along the sides of your Jeep (JK models also use the rear window brackets)
The crossbars are T-Slot and U-Bolt accessible for all of your mounting needs. Add a roof tent, cargo box, awning, gas/water cans, etc. The sky is the limit with the versatility of these racks!
We have two different lengths available for both the Jeep Wrangler JK and the newer Jeep Wrangler JL:
Half Rack Platform:
Dimensions: 5ft3in x 4ft7in
Rack weight: 58lbs
Adds approximately 3in of overall height to your Jeep
Recommended Maximum Dynamic Weight Limit: 175lbs
Max Static Weight Limit: 600lbs
Full Rack Platform:
Dimensions: 7ft3in x 4ft7in
Rack weight: 75lbs
Adds approximately 3in of overall height to your jeep
Recommended Maximum Dynamic Weight Limit: 225
Max Static Weight Limit 700
Features:
Disclaimer: Manufacturers of Jeep do not recommend putting anything on the roof of your Jeep
For a limited time
Half Rack Platform:
Rack weight: 58lbs
Full Rack Platform:
Rack weight: 75lbs
Features:
- 9 to 12 Cross Bars with T-Slots with Rubber Gaskets
- 6 to 8 Mounting Feet with Rubber Edgings to protect the Roof
- Adds a total of +3 inches of clearance
- Optional +5 inch Mounting Feet available
- T-Slot extrusions along top, sides, and bottom of outer frame
- Tools and Instructions included
