word302
Mostly sound logic, though shock extensions will not increase your travel.I’m really trying to absorb everything in all these threads. Sometime soon I need to get out on the driveway and put a name to these solid axle suspension pieces.
So far I’m looking to run a taller tire on stock Sahara wheels. I’d like to end up with a 33-34” tire to try to hold off a gear change with the 2.0. I’d rather tune it to see if that helps over 1500rpms. If not, I’ll regear.
With that in mind, I’d like to achieve full articulation without rubbing or super super minor as to not damage anything before I correct it. So I’m thinking quick end link disconnects for the sway bar. Recommendations? I saw JKS wants a tab cut off. Not sure how I feel about that.
Then that leads me to the stock painted flares. If I want the stock ride which we’re happy with, are spacers ok over springs and the unknown ride factor there? Will it ride the same if I get good shocks for the increased travel. Would Rubi shocks work or would they be too stiff for the stock Sahara springs? Or better to get aftermarket? I’d like to try to run readily available parts without a list of aftermarket parts numbers to reference over the years.
And shock relocation brackets to account for the extra travel?
Then that leads me to the stock bump stops. Do they need shortening/replacement?
Doing all that to get a 1-2” lift, again, hopefully just enough to clear 33-34” tires based on hearing 35’s would need a regear, and with a desire to try to keep center of gravity just high enough to get more diff clearance...then it seems I may...may need the Mopar lower control arms and adjustable (with low maintenance bidding preferably) track bar?
Fire away. Lol Is it a reasonable goal and does it sound like a plan? If not, please advise. Did I overlook anything? Thanks
