Another FTM-400 Ham Radio Install - Pic heavy
Bilymac
Bill
Auburn, CA
2006 Ram 2500, 2017 Chevy Tahoe, 2017 Harley Street Glide Special, 2019 Jeep JLRU
Started by puling the right-front fender. It really makes accessing the passenger-side grommet in the firewall a breeze. In addition to the power wires, I also ran another short section of wire, just in case I install something in the future.
I pre-purchased the little white fender clips, and I'm glad I did. 3 of the originals broke in the removal process. Even so, removal/re-installation is a snap.
Power comes directly from the battery, via a Powerwerx harness, and Power Pole connectors. The Powerwerx harness has fuse holders on both the pos & neg wires. (The other harness is for an RVi Toad Battery Charger).
I folded the windshield, and ran the Controller cable through the weatherstripping, to access above the dash, then into the kick panel area of the passenger-side footwell.
I then ran the power wire and Controller wire along existing wire bundles, to terminate under the passenger front seat.
I mounted a Diamond Antenna via a Diamond Mount to the spare tire carrier, running the coax through a grommet in the rear tailgate. The coax then followes existing wire bundles to the passenger front seat.
I added a little braided sheathing here to protect the coax, then ran it into the existing protective sheathing of the tailgate wiring.
I mounted the Transceiver to a thick rubber flooring material, using the stock Yaesu mount. The rubber is dense/heavy, and the texture keeps it from sliding on the carpet.
I usually run a little warm, even during the winter, so I always like a little cool air blowing. Since the Transceiver is adjacent to the vent, I hope air flow won't be an issue.
(The blue towels are just protecting the carpet from the front seat fame. I removed the 4 frame bolts, and tilted the seat back for better access).
The Controller is mounted using an adapted 67 Designs mount.
Everything is working okay so far. Haven't taken any SWR reading yet. I also have a mount that @Bobby Boucher made for me. I'll do a little testing with different antenna placements in the future.
Bilymac
Bill
Auburn, CA
Did you use 14 AWG - Trying to figure out my own and feel like 14 will be what works best.
I went overboard and used 10 AWG. The Powerwerx Fuse Holder I bought was 10, so I figured i'd use the same gauge all the way to the Transceiver.
Bill
PhoenixM3
2013 GT500 and 2015 Fiesta ST
Very nicely done! Pictures with embedded text really help people who'd like to perform a similar installation......
mbinzayed
Mohammad
United Arab Emirates-Dubai
Jeep Wrangler JL 2019
Helpful thred,
any recommendation on how many gauges I should go with for my 50w ICOM radio?
Bilymac
Bill
Auburn, CA
I have read that 14AWG is a minimum.
StinGray Rubi
Coy
Houston, TX
2019 JLUR
What is the dash mount called that you are using for your phone? That's the nicest one that I have seen yet!
Bilymac
Bill
Auburn, CA
The whole system is by 67Designs. Phone holder near the driver, GoPro mount in the middle, and Ham Radio control head on the passenger side.
tanner
Tanner
Scottsdale, AZ
2019 JLUR 2.0L
Clean install!
  • Where did you mount your mic? Any pics of this?
  • Did you mount an external speaker?
Bilymac
Bill
Auburn, CA
I have yet to decide on a permanent location for either my Mic or my external speaker. I bought the Mic extension, so it will go pretty much anywhere, once I can make up my mind. Right now it lives in the cup holder.
Bill
apettit7
Alan
Washington
Honda Element
IT
Great write-up and pics! Do you have the link for the white fender clips?
jeepdriver99
JD
Central Ohio
18 JLR 2 Door, 21 JLU TD, 06 GC, 54 Willys SW
Retired, W8BWD
Bill
I used a Magnetic Mic to mount mine on the console. It gives me easy access without taking my eyes off the road or trail.
mbinzayed
Mohammad
Great work ...
Any ideas for mounting Radio's Control Panels, I am looking for a solution without any drilling ... and looks nice ...
Cali-JeepJL
Rowan
San Francisco
Jeep JLUR
Nice install! Can you tell me where you got the adapter that connects the controller to the 67 designs arm? that looks clean.
Gibson Leatherworks
