missionale
- Jeepie
- Nov 19, 2020
- West of the Rockies
- 2020 JLU
My goal was a simple on-off push button switch which looked like an OEM install. So made small cutout in plastic cover using a Dremel tool, routed thru existing wire route with a wire loom cover that matched. Then routed over and down to washer hookup and used the disconnect that comes with the kit. I left off the remote and controller and created a wire loom to go to switch, the power/fuse and ground. Using the AAL mount with fuse block really comes in handy.
