Annoying plastic rattle
DOCXKT
NEW YORK
2018 JEEP WRANGLER JL UNLIMITED SAHARA
I’ve been having this annoying vibrating rattle right by the driver seat belt area and the rear trunk. I showed the service department where the rattle from the trunk is coming from and they refuse to fix it. I showed them pictures and instead of replacing the trim, they replaced the door handle... problems after problems. Help please @JeepCares
hoag4147
Colleyville, TX
2022 JLUR XR
Jeep Wrangler JL Annoying plastic rattle 2DB53B44-EC1D-44BF-8632-BC13E201D768
You positive that is it? More than not it is the sound of tailgate vibrating again rubber trim around window on hardtop. Most people put a strip of clear 3M tape across inside top edge of tailgate.
Rustydog
Palm Desert & Big Bear Lake, Ca
2019 JLU
Try applying a little bit of grease to your door latches. Not the metal hoop attach to the body but the latch itself in the door I almost tore apart that pillar to try and locate a rattle and it was the latches.
RedundanT
So. Il
2020 JLUR
Had a nasty rattle turned out to be my
M&P Compact in the glove compartment. Thankfully Gibson Leather has a fix coming.
DOCXKT
NEW YORK
I had someone drive and sat in the back and saw that trim hitting the metal so I’m pretty sure it is, as far as the driver side seat belt area I can’t figure it out.
DOCXKT
NEW YORK
Are you referring to the trunk or the driver door?
Roky
Roky
I was having rattle on certain bumps, sounded like coming from pillar between the two doors. Thought it was seatbelt adjuster but that wasn’t it. Today we went wheeling without top and doors and no rattle. Ended up being the outside door handles.
I haven’t tore into it yet to see what the fix is, but just knowing where it’s coming from makes it not bother me as bad, lol.
If you get a chance, pull the doors off and see if rattle is still there......... :) .
DOCXKT
NEW YORK
I was having rattle on certain bumps, sounded like coming from pillar between the two doors. Thought it was seatbelt adjuster but thot wasn’t it. Today we went wheeling without top and doors and no rattle. Ended up being the outside door handles.
I thought it was the seat belt adjuster too, but if I squeeze the plastic trim around the seat belt adjuster that sound can’t be heard..
JeepCares
Auburn Hills, MI
JL
Hi there, we are sorry to hear that this has not been resolved for you! Feel free to send our team a private message for additional support during your next dealer visit. We would be happy to help!
Kathryn
JeepCares
JeepJohn
Pennsylvania
Jeep JL
Kathryn
JeepCares
Is JeepCares a joke?
Met215
Maggie
CT
2020 Willys Wrangler JL
I have the same exact rattle on back of my 2020 jlu. I know it’s the black plastic because it stops when you press it. Any luck fixing?????
