Android Auto Wireless Dongle
JimmyZ
Jimmy
2021 2-Door JL Snazzberry Rubicon
Here's the one I use, it's magsafe compatible. I also got a magsafe ring attached to the back of my case and it works fine on any charger, my case isn't as thick as an otter though so you might need to research if the extra thickness can cause any issues.
https://smile.amazon.com/gp/product/B097BGJP7Z
https://smile.amazon.com/gp/product/B08S6XQFDM
Edit: and if you use the 67 systems you can use this to go from the 17mm of the mount to the 20mm of the 67 systems:
https://smile.amazon.com/gp/product/B0851TMQR4
Also do you know if it works for Samsung/Android?
PocketsEmptied
NC
'08 JKUR, '21 JLUR
Thanks checking it out now... Do you put the metal magnet ring on the outside of your case of inside your case on phone?
Goes on the outside of your case (the back side).
Yes, I use it with a Samsung S21+.
JimmyZ
Jimmy
Last questions (I think lol) will it stick good to the rubbery case of a OtterBox? And does it fast charge or just standard charge? I have a note 20 ultra.
PocketsEmptied
NC
'08 JKUR, '21 JLUR
I honestly don't know, but the ring is pretty sticky and sticks really well to my clear rubber case. Yes, the charger fast charges.
My only concern for you would be wirelessly charging w/ a thick otter case. If you can currently wireless charge with the case without issue then you will likely be good as the ring only adds a mm.
JimmyZ
Jimmy
Thanks I'm gonna give it a whirl. Thanks again for promptly answering all my questions. I'll let you know my results!
C.J.Rizzo77
Wentzville MO
2021 JL Willys
I have the AAwireless in my JLUR. I got lucky ordering it early. Looks like they have some big delays now trying to get parts.
Works well as long as you use the start stop feature to turn it off when the Jeep shuts off.
Downside is having two phones connected to it. By myself works great, my partner by herself works great. Both of us in the Jeep, forget it. Just fights itself, turning on and off, switching between phones.
Did you have any issues getting it to connect initially? I just received mine on the 4th of march. It goes through all of the setup procedures, but when it get to the select android auto on your radio screen part I get nothing. I have the 7" touchscreen, not sure if that makes a difference. Thanks
