The ATR Rock Rail Side Steps finally came in and installed them yesterday. It took forever. They are nice.Anyone install either the American Trail Rock Rail Side Steps or the Rampage Trailcrawler Rock Slider Steps? Thoughts...like dislikes, any pics?
This set directly from the Manufacturer. If you need to contact them, try email. The phone system is worthless, no one answers or returns voice mails.Where did you order from? Still didn’t get mine. They look great!
I had one on the drivers side I had to bend. The middle I needed a bar to bend then I put the bolt in. Passenger side no issues.got mine yesterday. Were any of your brackets not bent correctly? 3 of the 6 are wonky on mine and couldn’t even get them to fit.
They are mounted using the same factory holes as the Rubicon rock rails, you do not use the body mount bolts. Simple install besides the quality control from the sound of it.How do these mount? Are they body bolt mount?
I get it. My issue between getting the wrong ones and the huge delays I just dealt with it. I really liked the looked and no guarantee the next ones would fit either so I made the adjustments myself. I did find if you put the small bolts that go thru the pinch seem on first and tighten them slowly and evenly across all six of them that pulls the rails into better placement for the three larger bolts. If you try putting the three large bolts in first the holes are not even close.Thanks for info. A bit pissed that for $500+ I need to do any metal fab work. Not sure I’m keeping them!
Not sure if there are pics of the Rubicon Rock Sliders but they mount the same exact way. They provided hardware but you can use the same hardware from the Rubicon sliders. There is only three larger bolts that go in the factory holes and the pinch seems nuts again goes right in the factory holes. I had one bent mount that I had to bend, if not for that they are super easy to install. Dealing with company was not fun but in the end I really like them.Can you share some pictures of how they mount and what the hardware looks like? i know its difficult now that they are on your jeep... just trying to see what it looks like since there are no pictures available...
