Am I measuring caster wrong?
KNN
K
Maryland
2020 JLU Sport Diesel
I’m getting different numbers that don’t seem to match up.
85.5 degrees off the diff
0-2 degrees from top C
5 degrees from the bottom C
Numbers change depending on placement of angle finder. I have an appointment for an alignment but I’m curious what I’m doing wrong?
All measurements taken from driver side on a Clayton 3.5 Overland Plus lift.
Jeep Wrangler JL Am I measuring caster wrong? C1586E90-F93F-4453-9A32-756096EC1FD9
Jeep Wrangler JL Am I measuring caster wrong? E3BEA01A-DD69-48C1-9E07-2CB6793E8657
Jeep Wrangler JL Am I measuring caster wrong? 9C5FB618-715F-40A1-B134-0B393C0B2037
word302
Oregon
JLU
The Cs are extremely hard to get an accurate measurement from because it’sa compound angle. Any rotation of the measuring device will change the angle. The diff is 6° off from 0 so probably pretty close there.
KNN
KNN
K
Maryland
The passenger side diff reads 86.9. I’ve read this is not unusual. Based on these values is it safe to say I’m running between 9-10 degrees of caster?
Jeep Wrangler JL Am I measuring caster wrong? 9DADDFD4-6D19-43BC-8153-A3E6C6D05EA5
KNN
KNN
K
Maryland
I’m confused. How does the 6 degrees factor in then?
word302
Oregon
JLU
If the number decreases as you rotate the angle-finder down, then yes. If it increases then you are showing 3-4°, which is much more likely. This all assumes your floor is perfectly flat.
