Am I getting ahead of myself or should I wait for the long arm kits to hit the market.
  1. JlURT
    JlURT Well-Known Member
    First Name:
    WILLY
    Vehicle(s):
    JlURT18'
    Aug 15, 2018
    Orlando,FL
    90
    Liked:
    90
    I'm trying to build my JLURT and pulled the trigger on a 2.5 RK X factor mid arm kit stage 0, that I can still cancel. Now I'm kind of thinking maybe there is a "better" kit out there, like the long arms kits. I keep hearing long arms give a better ride on and off the highway. I want to build it right the first time and not double down later. I'm really considering canceling that order till I have a better understanding on if I'm making the right choice or not. I'm sure the kit is quality but the question is, is the lift better because it's an long arm which causes the better on and off road ride or is it an different application for different people kind of situation?
    A little more info:
    I'm going to be running the patagonias in 38x13.5r17 due to the light weight with C rated load. I have my high fenders and stubby bumper. Along with the Falcon 3.3 shocks to control the ride quality to my taste. I also want to keep my COG as low as possible without limiting my suspension as much as possible.
    Any helpful info negative or positive will be greatly appreciated.
    Thank you.
  2. TroyBoy
    TroyBoy Well-Known Member
    First Name:
    Troy
    Vehicle(s):
    Jun 14, 2017
    Parksville
    1,198
    Liked:
    1,117
    Yeah the long arms are supposed to ride better both on and off road. I can tell you that you will most likely be very happy with the 2.5" RK xFactor. I run that kit and I'm extremely happy with it (Although I only run 35" tires). I assume you are getting aftermarket wheels too. The kit doesn't work with stock wheels because of the way the control arms are bent. Also, make sure you invest in long travel shocks to get the benefit of the awesome flex the RK gives you. I run the Fox 2.0 shocks for a 3.5" to 4" lift.
  3. Martindfletcher
    Martindfletcher Well-Known Member
    First Name:
    Martin
    Vehicle(s):
    Ducati 1299s, 2018 JLUR
    Jan 3, 2018
    San Diego
    1,450
    Liked:
    1,231
    I used wheel spacers with stock wheels and 37’s.
    TroyBoy likes this.
  4. bumpit
    bumpit Well-Known Member
    Vehicle(s):
    2015 Grand Cherokee 2019 JL Rubicon
    Sep 30, 2018
    Missouri
    229
    Liked:
    285
    On road i cant tell a difference in jk long arms. My buddy has a long arm 2 door jk rubi on 37s and i had a 2 door rubi with xfactor 2.5" with 37s and we wheeled the same stuff. I think mine had a better ride because i had better shocks.
    The $$ that a long arm costs not to mention the extra work installing it has not been worth it to me on the jk and I doubt it will on the jl I just ordered but thats just my opinion.
  5. doug_outlawoffroad
    doug_outlawoffroad Active Member
    First Name:
    Doug
    Vehicle(s):
    2018 JLU (Black)
    Apr 17, 2018
    Greensboro, NC
    Liked:
    30
    Long arms will perform better all around. If you can wait until January, Rock Krawler should have a JL Long Kit available. Springs, shocks, kit box will all the same, but those arms will certainly be different.
  6. TTEChris
    TTEChris Well-Known Member
    First Name:
    Vehicle(s):
    2018 JLU Rubicon & Sport(Wife)
    May 17, 2017
    Houston, TX
    2,036
    Liked:
    4,468
    Garage Profiles:
    I have @ROAM long arms and can tell you the difference is night/day. I drive a lot of JL's, including my wife's that has all 8 adjustable "short" arms. Everytime I get back in mine I realize how nice I have it.
    TroyBoy likes this.
  7. bumpit
    Vehicle(s):
    Sep 30, 2018
    Missouri
    229
    Liked:
    285
    What is so much nicer? I found at 2.5 -3.5" of lift on road if I was blindfolded I could tell a difference on road.
    I understand the longer the arms the smoother the ride on road but the jk and jl arms arent exactly short like the tj and yj. Legit question as Im assuming im missing something.
    Another thing to keep in mind is cost. If your doing your own work or not worried about cost great. If you have to have a long arm put on at a shop it can get costly depending on how it mounts if your in a budget.
    I know this is a jk but its a rk 2.5" mid arm xfactor. To give you a idea of how much travel you can get out of them.
  8. TTEChris
    First Name:
    Vehicle(s):
    May 17, 2017
    Houston, TX
    2,036
    Liked:
    4,468
    Garage Profiles:
    On my JK I actually went from a Metalcloak short arms to RK 3 link long arms(no other changes) At the 4" of lift I was running I actually felt the RK arms rode stiffer, but that probably has to do with the metal joints on the ends vs the Metalcloak duroflex joints. They both flexed extremely well, but the RK long arm did handle better offroad.
  9. bumpit
    Vehicle(s):
    Sep 30, 2018
    Missouri
    229
    Liked:
    285
    #9 Oct 25, 2018
    Im not denying a long arm esp on more than 2.5" of lift will flex better and perform better offroad. I was simply saying on road with 2 quality setups I couldn't tell the difference. Great lookin jk and the flex is awesome but its also got coilovers which im sure you know are a different beast vs reg spring lifts. All I was pointing at was that if your unsure if you need a long arm lift you you more then likely dont need one. When your stepping up to coilovers and long arms your usually wheeling stuff that requires that lvl of investment in time and money. Not knowing the op background I was just assuming by the questioned he asked that he is new to the offroad world.
    I see you have good taste in bumpers lol. I was disappointed jcr doesnt make it anymore.
    My old 4 door also sporting the dagger :rock:
    TTEChris likes this.
  10. TTEChris
    First Name:
    Vehicle(s):
    May 17, 2017
    Houston, TX
    2,036
    Liked:
    4,468
    Garage Profiles:
    Looks great! I loved JCR's products when they came out. I had their dagger frame chop on the rear of that JK as well.
    I had three JK's after that Dozer, and all of them either got Metalcloak or Synergy short arms(When they went to the metalcloak style bushings). I also didn't think there was much of a benefit on road, but at the time it really wasn't a fair comparison due to the change in manufacturer/joint style. My buddy who only had Teraflex lower arms with his EVO bolt on coilover kit purchased my Metalcloak arms and was blown away from the change in ride just by swapping out the arms. They all had around 3-4" lift, except my 2dr which had 2" OME springs.
    I have two JL's in the household, my Wife's with full adjustable ROAM short arms, bypass shocks and 2.5" lift, and for comparison(Before I went coilovers) mine with 4" lift and ROAM long arms. If you drove them back to back on your same daily commute you would swear you were in a different vehicle. While both ride/handle nice, the long arms are so much smoother over bumps(Both use the same joints). Her Jeep feels sportier, but mine felt more like an old school Cadillac just gliding over those same bumps(If that makes any sense.) Crappy road imperfections can still be felt in both, and I've all but given up trying to get rid of that in any solid axle Jeep :headbang:. Well, I could run the tires at 10psi but that doesn't sound safe on road. :beer:
    Also, not all long arms are equal. While the RK arms offered incredible clearance, they were much shorter than other manufacturers at the time. Back then I didn't care so much about ride quality, and just wanted to build a capable but still semi livable daily driver.
    I now want my Jeep to ride like a Mercedes S550 with airmatic suspension on road :facepalm:, and handle fairly well offroad. I realize my hopes are unrealistic, but so far my JL handles/drives better on road than any of my past JK's.
  11. OffRoadWarehouse
    OffRoadWarehouse Well-Known Member
    Rock Sponsor (Level 1)
    First Name:
    Vehicle(s):
    2018 Jeep JL
    May 9, 2018
    San Diego, CA
    154
    Liked:
    115
    Occupation:
    Jeep, Shock, Suspension, and Export Specialist
    Garage Profiles:
    If we are only concerned with ride quality, and not top level offroadability:
    Long-Arm lifts are also not going to be necessary for shorter lifts like the 2.5" and possibly up to 3". Adjustable short arms will work fine for ride quality changes (loss of caster) in the suspension and work for even the most picky of customers. Heck! Throw a Teraflex Arm Correction bracket on there if you dont want to invest in any arms.
    Once we start talking about 3.5" and above lifts, that's where control arm angle is being more severely affected and a Long-Arm makes complete sense to flatten out those angles.
    Icon_Adrian and TTEChris like this.
  12. IPvFletch
    IPvFletch Well-Known Member
    First Name:
    Kevin
    Vehicle(s):
    JLUSS
    Aug 26, 2018
    ATX
    520
    Liked:
    339
    It seems like long arms hold caster better as the front springs compress and uncompress going over bumps, because the angle changes less over that same amount of compression.
    I don't see how the longer control arm could enhance ride quality/harshness going over bumps, though. I mean springs and shocks would definitely impact that, but I wouldn't think control arms could.
    Off-road it seems like longer control arms will yield better extension when fully uncompressed.
  13. TTEChris
    First Name:
    Vehicle(s):
    May 17, 2017
    Houston, TX
    2,036
    Liked:
    4,468
    Garage Profiles:
    This theory may be off, but I believe the more parallel the ground the control arms are the better the ride will be since the springs/shocks will be doing most of the work. The more of an angle the arms are down I would presume would be putting force on not only the springs/shocks but now the control arms to the body.. The drop brackets mentioned above do essentially the same thing as a long arm kit for ride quality at the expense of those brackets hanging down. I would rather drag on a control arm than catch on those brackets offroad, but for those that will never go rock crawling the brackets do provide a drastic improvement on ride quality/drive-ability as well.
    IPvFletch likes this.
  14. Rock Krawler Suspension
    Rock Krawler Suspension Well-Known Member
    First Name:
    Tech Support
    Vehicle(s):
    Red JLUR, White JLUR, Yellow JL (3 so far), Bikini Diesel JLU, Billet JT, Hydro Blue JT
    Oct 15, 2017
    Waterford New York
    453
    Liked:
    396
    Our long arm kits will be out January 1st, the 3.5" Adventure Series Long Arm will be on display at SEMA next week. On Nitto 38x13.50x20's, not aired down, we went 41.5" from ground to bottom of tire on our forklift. The final details are not finished yet, but here's a quick peek.
  15. 19JL
    19JL Well-Known Member
    First Name:
    Bobby
    Vehicle(s):
    2019 Jeep JLUR
    Nov 7, 2018
    Bend Oregon
    104
    Liked:
    96
    I can’t wait for this kit!
Loading...
Share This Page
