Ratbert
- John
- Jun 20, 2020
- COS region, CO
- AEV JL370 JLURD , AMG GLC43
- Build Thread
- Link
- Occupation
- Software Engineer
Aluminum is significantly lighter than steel. It also doesn't rust.I read that steel skid plates will slide over the rocks much easier and the aluminum can have a tendency to grab and resist more when sliding off a rock.
Most sliders or rock rails I see are made of heavy steel, I don’t see too many aluminum rock rails. So if steel is used on a rock rail and designed to support the weight of a wrangler when on a rock or used as a jack point then why would thinner aluminum underbody?
I’m sure aluminum is good enough but I would use steel for our rocky desert rock crawling.
I went with aluminum since my turbo diesel is built for both rock crawling and overlanding. I don't like exceeding weight limits tooo much. The aluminum NVM skids add 30 pounds. I've also added UHMW onto those so it really slides....I'm guessing significantly better than steel?
