Aluminum soft shackle recovery rings?
DadJokes
Daniel
Indiana
www.youtube.com
Sahara
I can’t recall where I read this now (here or Overland Bound) but they claimed with a temp probe measured a 7 degree Celsius temp increase over the course of 20-30 ft. I’m sure searching will turn up what you’re looking for. Worst case, I figure just keep a spare soft shackle as that seems to be the one taking the wear and tear.
Hayseed_JLUR
Midwest
2019 JLUR, 2015 JKU
I saw that one too. Is a 7C rise detrimental to the soft shackle or not - that seems to be the question.
Chocolate Thunder
Jeremy
That amount of heat doesn’t seem like a lot to me. However is the amount of surface abrasion being measured? The more I think about it, the more it seems insignificant from a practical standpoint.
I don’t wheel every weekend or even every month. For people who use this equipment routinely it might matter. I have it “just in case” and I haven’t been able to get my Jeep stuck yet or run across someone in need of help who didn’t have recovery gear, so maybe I’ll never need it.
American Adventurist
West Florida
2018 StingGray JLUR
It seems like this method works fine, but causes a lot more friction and thereby wear on your straps compared to using a snatch block. No?
It does. And friction is the enemy of your expensive synthetic lines.
There's a lot of misinformation about them. Anyone who says friction is minimal with these rings is either A. giving you a BS answer to sell you one or B, has never pulled 50 feet of line through one hard. You don't need speed to cause friction if you have enough load.
That said, they're not "new" and have been used in sailing forever.
https://www.velasailingsupply.com/tylaska-ring-ferrule-fr26-for-1-in-line-38mm-id-x-96mm-od/
Applications
Ferrules are ideal for applications such as barber haulers, spinnaker twings or other uses that have small turning angles and little line movement. They also work great for backstay adjusters when used in a high purchase cascade configuration. Ferrules start having frictional heating and wear problems when there is significant line movement so conventional pulleys are still better for applications such as mainsheet and halyard blocks.
I can see using one to redirect a winch line that's being used to steady a vehicle and as an anchor.
Just as the friction increased the load on the winch it can be used to increase the holding strength of a winch line being used to steady a vehicle. Instead of a pulley it's being used as a capstan.
But that's about it for me. Not something I'll buy or carry around, and I certainly don't advocate their use in place of a properly tested and rated, quality pulley block.
Want the best recovery gear money can buy? Check out Safe-Xtract. This is what SOCOM is using in Afghanistan and Africa right now.
  • Like
Reactions: J0E
RockyMtnHigh
Corey
Erie, Colorado
2018 JL Rubicon - Punk'n Orange
I beg to differ. As long as the ring that the winch line is feeding through is moving (at the same rate as the rope, no slippage) then the winch line see's no additional friction. Your soft shackle however, see's a lot of friction. I've drawn up a diagram illustrating this point. The snatch ring setup on the left, and the traditional snatch block on the right. Again, this assumes there is no slippage in the winch line on the snatch ring. That seems to be the case, but there is no way to know for sure. Also, the traditional snatch block could also have slippage if your bearing is bound up.
RockyMtnHigh
Corey
Erie, Colorado
Color me clueless but what exactly is so broken with the traditional snatch block design that this is fixing?
Nothing's broken. Arguably however, a one piece design has a lot going for it. Nothing TO break, no moving parts, lighter, and cheaper.
  • Like
Reactions: J0E
cosmokenney
cosmokenney
Cosmo
Loyalton, CA
2019 JLR (2-door)
The big deal about these is if the attachment point breaks, would you rather have a 5 or 6 pound steel snatch block flying towards your head at a million miles an hour -- or a less than 2 pound aluminum ring? Yes, snatch blocks are the best when it comes to functionality. And there is less friction in a bearing based snatch block, but the winch line moves the pulley so slowly I really don't think it matters.
  • Like
Reactions: J0E
West Florida
2018 StingGray JLUR
Nothing. But now there’s new overland bling that you NEED...
1996cc
Oregon
21 JLUR 392
with this logic, you wouldn't have lights in your house and would still be using oil lamps. ‍♂♂
  • Like
Reactions: J0E
cosmokenney
cosmokenney
Cosmo
Loyalton, CA
2019 JLR (2-door)
Used the ring to winch out a full sized Silverado on Thursday. He was buried in snow up to his axels. Poor young dude in a t-shirt and no gloves was digging out with his hands.
I used the ring to increase my winch pulling power. Two bumps of the winch and he was out.
Hayseed_JLUR
Midwest
2019 JLUR, 2015 JKU
Did you notice any marring or melting of the the rope or shackle? It doesn't sound like you used it too much or enough to really notice anything.
cosmokenney
cosmokenney
Cosmo
Loyalton, CA
2019 JLR (2-door)
Here's a picture after use. No sign of wear at all. The coating on the rings is slick like Teflon or something. And to be fair there is no way the rings would have gotten hot since we were in the snow. It was about 31 degrees. Just an FYI, I did add the shrink tube near the knots to keep the string wraps (like the red ones you see near the loops on the opposite end) in place. When I received them from the factory, the wraps were loose and I had trouble tightening them.
roaniecowpony
Retired Engineer
I know this is an old thread but people search and this thread automatically associates in a list below for similar subjects. So I think this question is worth responding to.
A traditional steel "snatch block " weighs from a few times more than a soft shackle and aluminum ring, to many times more.
With one pulley, whether a steel snatch block or aluminum ring, I can double the pulling force, while keeping the loads on the winch and rope the same. More pulleys, more force. With 2 pulleys, I can also winch a vehicle sideways (which I have had to do). With 3 pulleys I can have 4 times the pull or i can rig to winch backwards. More pulleys, whether steel snatch block or aluminum ring, give you more capabilities. Now who wants to haul 3 steel snatch blocks around?
