Alpine audio system vs. stock
SOON
Roseville CA.
JL Willys 4XE
Has anyone listened to both. Is the $1200 for the Alpine worth the upgrade?
BlairF
Blair
Humble, TX
2018 JLUS-S Mojito! - 2014 Challenger RT Classic (SuperCharged) - 2016 Dodge Durango RT
Technology Incident Management
Stock system sucks.
OldGuyNewJeep
Don
CT
Vandy23
Craig
Jersey
18 JlU Sahara
Worth it for sure! Every other car I have owned I have installed a custom audio system. Back in the day you didn’t have to worry much about integration, but today you have to balance the functionality of the whole system with the introduction of aftermarket components...and some times it’s just not worth it. The Alpine system, for a stock system is pretty darn good! Price point is not all that bad for what you get considering that everything works well together. I have driven topless and sound holds its own. Of course I would love an EQ to smooth things out a bit, but overall the Alpine system with the 8.4 screen has been great so far.
seguerski
Josh
Columbus, OH
2018 Jeep JLU Sport S 3.6L Sting Gray, 2014 Jeep MK Compass Latitude 2.4L
I'm probably in the minority here, but I feel the stock system is good. Now maybe it's because I didn't fuss with settings in Alpine versions, but the JK alpine setup seemed to have more oomph to me than Alpine in the JLs. I've had the top off in my Sport S and had no issues with clear volume at high speeds. I feel that just adding a hideaway sub is all that is needed to get more punch out of the stock setup. For me, the $1200 price tag for Alpine upgrade was not worth it. Best advice I can give is to go and listen to both systems using music you like and don't be afraid to play with settings. I found using the loudness setting in base system (disabled in Alpine upgrade) gave me what I wanted with Bass at 8, Mid at 2, and Treble at 4.
viper88
Nick
IL
Any of you guys with Alpine have the Active Noise Cancellation?
seguerski
Josh
Columbus, OH
I heard rumors that ANC only applies to Alpine systems on the 2.0L Turbo with BSG...
viper88
Nick
IL
I was told the same by a couple of dealers. I just wanted to confirm. Thanks.
Rubicon JLB
Vermont
2018 JLU Rubicon
Alpine is totally worth it, unless you are a totally serious audiophile...
For the layman that likes to listen to music while driving, it’s a pretty sweet setup. No hassle, pre installed, does the job.
aestes89
Adam
Arizona
2018 Wrangler JLU Sport S
Infrastructure Analyst
Doesn't really answer your question, but you can do something in between, even on a budget. The stock system, while better than a lot of stock systems I've heard, is pretty lacking. I replaced the four 2.5" speakers with 3.5" infinity speakers. at $50 a pair and about 20 minutes to swap them out, not bad. I left the four 4" speakers intact. With this change, the highs are MUCH clearer, but there is no low end. I added an Alpine class D mono (500w rms) amp ($100) and it hides completely under the driver seat. Next, a 10" sub in a 12x12x12 box fits pretty neatly in the 14" wide nook behind the rear seat. (sub $110 / box $30). With factory speaker adapters, wiring kits, etc totaling around $50. Grand total, right around $400. Does it sound as good as the Alpine? No. Does it have the 8.4 screen? No. But an afternoon and $400 can get you pretty good sound!
