Alpha HD tire mounting kit.
Turbo_punkn
Greg
Bath, pa
2018 JL
@TeraFlex , if I buy this for my Jeep can you have Dennis wood personally deliver it to me at the NJ Jeep invasion in June?
TeraFlex
TeraFlex
teraflex.com
JL, JT, JK
Ha, that would be nice! Unfortunately Dennis travels pretty light and doesn't bring product to sell at shows. But you can for sure snag one and have it installed so you have something in common to talk about :rock:.
Turbo_punkn
Turbo_punkn
Greg
Bath, pa
2018 JL
If I buy it can you have Dennis install it? I’ll bring all the tools.
Turbo_punkn
Turbo_punkn
Greg
Bath, pa
2018 JL
Haha. I bet he wishes he could leave the show for an install. But feel free to ask him.
It’s all good, mine is supposed to be delivered tomorrow and I’ll probably put it on right away. I don’t wanna let it sit in a box for the next month.
Cypher
J
AZ
Cybersecurity Leader
@TeraFlex , is the backup camera housing the same outside diameter as the JL factory one? I am looking to run a set of AEV Salta JK wheels, and they won't fit over the backup camera on the factory spare tire carrier. It is close enough that maybe a slightly smaller od or even the spacing of the wheel on your Alpha carrier may make all the difference in the world. The factory one has a taper at the back and quite a few JK wheels have issues. Some can use a spacer between the wheel and the mount and it fits, so wanted to see if the design with yours would allow the Salta to mount.
I plan to order one either way, but that may be a huge selling point for you if it allows a wider selection of wheels to fit on the spare mount.
I don't want to buy the Salta until Know if I can carry a spare.
Thanks in advance for any information you can provide.
TeraFlex
TeraFlex
teraflex.com
JL, JT, JK
It is close to the stock diameter, but i want to say just slightly smaller. We have seen many Jeepers use it with a variety of wheels. I can snag an actual measurement tomorrow.
Jake
Cypher
J
AZ
Jake
@TeraFlex thanks for looking into this for me. The AEV JK wheels had the opening just small enough to not work with the factory backup camera. I am not sure the JL specific Saltas are coming so the old version may be the only option. I really appreciate your help looking into this. (I will most likely get an alpha he either way, but this will be even better if the wheel fits better.)
Kbarakeh
Khalid
Wichita, Ks
2019 Jeep Wrangler Rubicon
@TeraFlex does this kit make the camera stick out further than the stock JL carrier? I’m having an issue with my -44 offset method wheels blocking half of my camera angle view..
Alanscott1
Central NJ
2021 JT Mojave
A&P Mechanic
I had this issue with my methods as well. The camera does stick out further, however, you’ll see maybe 20% less of the wheel than you do now.
Kbarakeh
Khalid
Wichita, Ks
Thanks for the response. What type of Methods are you using? I have the method MR106 , I even considered going with the non beadlock version of the same wheel design (MR312) with a less aggressive offset for the spare hoping it would reclaim some camera angle.
Alanscott1
Central NJ
2021 JT Mojave
A&P Mechanic
I have the MR701s
Edit: here’s what mine looks like
