*ALL NEW* Q-Performance Stealth Winch!
Quadratec
Quadratec
Summit Sponsor (Level 3)
West Chester, PA
www.quadratec.com
CJ, YJ, XJ, TJ, JK, JL
KDB
Kevin
WI
2018 2 Door JLR
Sure thing - here are the specs:
Q10 Performance Stealth Winch Specs
Rated Line Pull (Single Line):
10,000 lbs (4536 kgs)
Gear Reduction Ratio: 210:1
Motor (Series Wound): 12 Volt / 4.9 Hp (3.65 Kw)
Drum Size: 2.64” x 8.35” (67mm x 212mm)
Winch Line: 3/8” x 82’
Overall Dimension: 21” x 6.375” x 10” (533.4 mm x 162 mm x 254 mm)
Net Weight: 85.0 lbs. (38.55 kgs) for Steel Cable / 61.0 lbs. (27.67 kgs) for Synthetic Line
Mounting Bolt Pattern: 10” x 4.5” (254mm x 114.3mm)
Q12 Performance Stealth Winch Specs
12,000 lbs (5443 kgs)
Gear Reduction Ratio: 294:1
Thanks!
-Rick
Thanks Rick/@Quadratec, Assuming that the mounting bolts are all grade 8 but do you know if the internal hardware on/in the winch is stainless steel (rust concerns)?
Quadratec
Quadratec
West Chester, PA
www.quadratec.com
You're welcome, Kevin! The mounting bolts are Zinc plated class 10.9 steel. I pulled this from a BoltDepot.com: "This is a tempered, medium carbon steel. Class 10.9 is stronger than class 8.8, and is commonly found in high strength automotive applications. Class 10.9 is similar to grade 8. Zinc plated for moderate corrosion resistance."
Not all the bolts on/in the winch are stainless. I don't have a full breakdown of which are/are not. I do know the clutch lever allen bolt is not stainless. The winch is IP67 rated. We will have a parts breakdown as we do for our other winches. This will be coming in the next few months and will list all the replacement parts available.
Thanks!
-Rick
Done Right LED
