You won't need an alignment as no steering components were affected but you might consider a 1" leveling kit at a minimum. If it was mine I'd go ahead and get the Rubicon takeoff suspension from the heaviest 4dr Rubicon model you can find and also add a 3/4" front coil spacer to level things out.I added 33 AT wild peaks, front and rear steel bumpers, steel rock rails and an 80 lb 12 k winch. Should I get an alignment and/ or new coils and shocks due to about 350lbs if added weight? I have a sport 2020 JLU.
Thanks in advance!
Great info and link! I was gonna do a 2.5 inch spacer kit from rough country but now I may do the rubicon shocks and coils with the spacer lift only in the front. I’m about to go to Beasley Knob and want to make sure I can handle it. Thanks man!!You won't need an alignment as no steering components were affected but you might consider a 1" leveling kit at a minimum. If it was mine I'd go ahead and get the Rubicon takeoff suspension from the heaviest 4dr Rubicon model you can find and also add a 3/4" front coil spacer to level things out.
Did that on my 2 dr and it's nice and level now, rides great and easily run up to 34" tires.
Here's a thread on the install, applies to a 4dr too.
https://www.jlwranglerforums.com/forum/threads/rubicon-suspension-on-2-door-sport.40700/
I am going to purchase a willys take off suspension from a 4 door hard top. I am told it’s pretty comparable to the rubicon. Do you think that would work? And how much lift would I net? I’m thinking about adding a little rear spacer too. Do I need shock extensions or bump stops??You won't need an alignment as no steering components were affected but you might consider a 1" leveling kit at a minimum. If it was mine I'd go ahead and get the Rubicon takeoff suspension from the heaviest 4dr Rubicon model you can find and also add a 3/4" front coil spacer to level things out.
Did you double check that a Willy's suspension is same as a Rubicon? I would suggest that before spending money. They say even different Rubicons have different stiffness depending on the OEM bumpers.I am going to purchase a willys take off suspension from a 4 door hard top. I am told it’s pretty comparable to the rubicon. Do you think that would work? And how much lift would I net? I’m thinking about adding a little rear spacer too. Do I need shock extensions or bump stops??
Only the shocks are the same, you won't get the Rubicon springs so you won't get the additional liftDid you double check that a Willy's suspension is same as a Rubicon? I would suggest that before spending money. They say even different Rubicons have different stiffness depending on the OEM bumpers.
