Alert - High Amp Fuse Array related
CarbonSteel
FYI - the towing package DOES NOT guarantee that you have the 100A version of the fuse array. My 2019 Rubicon has the "Trailer Tow and HD Electrical Group" option, and it had the 60A version. I discovered it when I replaced it with the 100A version.
Jeep Wrangler JL Alert -  High Amp Fuse Array related 20230611_124312
Outdrluvr28
Blanchard, OK
2020 JLU
I just made sure I matched the serial number when ordering a new one to the one I pulled out. 8853AA
CarbonSteel
Hmmm...the one in my photo is a 8853AA and it is a 60A. I bought two 100A fuses (one for a spare) because I plan to change my fan to a Gladiator model which requires 100A.
The 100A array is part number 68368854AA
Outdrluvr28
Blanchard, OK
2020 JLU
Good idea! I just remember someone advising me to match the numbers as one did have a higher amp. I guess that makes sense since you’re upgrading the fan tho. Have you already installed it? Any issues?
Ormond Beach, Florida
Retired at 55 ..
If you have the tow package you would want the high amp fuse array with the 100 amp fan fuse. Probably because of supply chain issues some JL's with tow package inadvertently left the factory with the incorrect high amp fuse array.
CarbonSteel
Yes; it has been installed since 11 June with zero issues and it is 100% plug and play.
CarbonSteel
True; but just a note to remind everyone not to assume, but to verify if needed. I bought my Jeep before the COVID madness/supply chain junk happened, yet, FCA hosed up the fuze size.
TKL223/3
Jon
Arkansas
Jeep JLU Rubicon
Same for me.
fireman2498
Maryland
2019 Jeep Wrangler Unlimited
A this fuse a ray cause issue like, messages on display?
Service shifter
Auto park disabled
Service electronic stability control
“No Bus” flashing in bottom of display panel
Speed and tach needles bouncing
Will Not shift, in limp mode, only able to get to 5-10mph
all this popped up after they found a bad chaffed wire that lead to the canbus and they fixed that splicing it back together.
Jeep has been in out of shop the last few months. They did replace the main battery, I don’t have an auxiliary battery.
DaltonGang
Doesn't Play Well With Others
Why not just go with the 100 amp array on all, when you need to replace any?
ChapChai
Glenview
'20 JLUR '17 BMW X5, '04 Honda VFR
So my 202 JLUR 6sp w tow package has the 53aa. Getting the start stop service light @!
Batteries are good, all fuses check out. Going insane and finding this little fact has me spinning.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
The start stop service light can indicate that the stop/start system has been disable due to issues with other systems like engine misfires. Do you ever get a CEL and have you ever used a scanner to check for error codes?
ChapChai
Glenview
No check engine light, everything seems normal otherwise. Awaiting the scanner. At this point more peeved about the wrong fuse being used when built.
