DaltonGang
- Sep 29, 2018
- Doesn't Play Well With Others
- 2018 Wrangler JLU Sport S, Rubicon Suspension, Rims. Firecracker Red
I've been doing some reading on the difference between the AGM and the Standard(FLA) batteries. FLA(Flood Lead Acid) . it seems the big weakness our AGM batteries have is that once they are fully discharged, by the crappy Aux Battery, their lifespan is now cut short. The AGM likes to be charged above 90%, and below 50% it's days are numbered. Our Aux battery seems to be taking out main batteries at a fast pace. This seems to be why many here change both batteries at the same ti.e, or end up replacing the main battery after the Aux is replaced.
Also, it seems the AGM deteriorates fast with high heat. Hmm, you think the Wrangler might be a little hot in the engine compartment?
