Sydwaiz
- Mark
- May 11, 2020
- Torrance, CA
- 2021 JLURD, 73 CJ-5
Looking to add some more aux switches beyond the factory ones. I thought I was set on getting the Switchpros and using their grab handle mount because I like how nice and tight it fits up against the dash and doesn't get in the way of the vent. It appears that any unused circuits will leave a loose wire hanging from the distribution block under the hood.
Then I came across the Spod and really like the touchscreen and the fact they apparently have a bracket for the Ecodiesel. Switchpros does not offer an Ecodiesel bracket yet. I would have to use a ball mount and arm with the Spod and I'm afraid it will impede the vent opening and just plain stick out too far although if Spod is a better product, I can over look it.
Then there is Voswitch which is so cheap, I wonder about the quality and manufacturers origin. The backlighting is only one of four colors unlike Switchpros where you can program it to match the dash if you want.
So now I'm leaning toward the Spod. To those that are using any of the three brands listed, What are your thoughts or what have you learned along the way if you chose one over the others. Are there any other brands out there that I don't know of yet? Pros and cons? I wonder if I can use the Switchpros grab handle bracket with the Spod touchscreen without too much trouble. TIA
edit: I have the Sky One Touch top so overhead switches are a nogo.
https://www.4x4spod.com/bantamx_touchscreen_jl_jt
https://store.switchpros.com/sp-9100-switch-panel-power-system/
http://www.voswitch.com/JL100-switch-Control-System-for-Jeep-JL-and-Gladiator-p1281852.html
