Warpath
Another good looking wheel!! Make sure you post up some pics when you get them on!!17x9 with a 4.5" backspace.
I am going with 17x9 Method 105 beads.
I had the Mopar all weather mats installed. And had the drain plug in place in the mats themselves.Did the interior stay dry? I keep looking for JL carpet removal tips. Wondering if the seat wiring or any other is an issue. I'm at 105 days anxious and still counting. Dealer says arrival between the 16 and 26th. This is the hardest order wait ever!
Ummmm...wow!A few raw videos with no fancy music.
Thanks!Off topic but congrats on finally getting the jeep - I know it was "stuck" forever.
Phone mount, what is that? I have a small iottie that I put on the driver's side windshield but looking for something for the top of the dash....
Does having a metal plate and magnet right behind your phone affect it? Have you used compass for anything since and gotten good resultsThanks!
Yeah it's a magnetic mount. Used it for a few previous cars I have had.
Adhesive on the mount side. Phone has a slim metal plate inside the case (you can also just stick it to the phone itself).
Works perfectly.
I have the older version - the new one looks a little cleaner.
https://www.scosche.com/magicmount-pro-dash
Their sample picture is how I have mine mounted in the JL.
That's a negative.Does having a metal plate and magnet right behind your phone affect it? Have you used compass for anything since and gotten good results
And yes, water got in from the drain port.
I removed the carpet under both seating areas. It all removes without removing anything else. There are perforated tear areas where you have to separate the carpet that wraps around certain things. You'll feel the perforation when you get there.
I have since just kept the drain plugs in the floor itself. And the mat's drain ports just sit on top.
ThanksAwesome! Seemed to handle it just fine. Well done.
Can I ask what front bumper you're running?
The bumper is heavy - especially with my `100 pound winch. I used two buddies to hold it in place as I bolted it down.How was the install on the DV8 bumper? I've been looking at getting one of these. Were the lights plug in or did you have to splice them in and how was the fit on the bumper?
Thanks!
Thanks for details on the bumper! As a follow up (sorry to hijack your thread into a thread about your bumper!), did you compare to the FS-13? I’m having trouble understanding the differences between the 13 and the 15.The bumper is heavy - especially with my `100 pound winch. I used two buddies to hold it in place as I bolted it down.
It was easy, other than the weight, of course.
I don't have the LED lights - the fogs bolted right up with no problems. I believe the LED lights have a different bolt pattern than the standard halogens do, so they might be an issue. I am not entirely sure though.
