7 to 10 degrees upIs your front sway bar flat, even with ground? Is it at a steep angle? What is best?
It is which is why i ask. Thanks.with the 2.5 metalcloak lift I would think yours is pointing up some. From what I have read Metalcloak 2.5 and 3.5 lifts are the exact same components except for springs and the length of the sway bar links is based on the 3.5" lift.
For the electronic sway bar on the rubicon the end links that come with the Mopar lift will bind and stop your sway bar from its full misalignment. I got the rk no limits end links , they are made specially for the electronic disconnect. They allow up to 60 degrees of misalignment. But with a couple of wrenches, you can always disconnect the regular way too......I've been wondering this... is there anything limited if the sway bar is pointed down (mopar 2") when the sway bar is disconnected? I've noticed a lot of pics on the forum and insta and have noticed many people have their sway bar links pointing up at ride height. Is it worth investing in longer sway bar links for any reason?
I’m pretty sure you don’t want it pointing down at ride height. You risk having the sway bar flip at full articulationI've been wondering this... is there anything limited if the sway bar is pointed down (mopar 2") when the sway bar is disconnected? I've noticed a lot of pics on the forum and insta and have noticed many people have their sway bar links pointing up at ride height. Is it worth investing in longer sway bar links for any reason?
That looks normal for that lift.This where mine are and I'm pretty sure it's right. But I am curious if that's the case. Rides just fine.
Yeah they’ll work fine, I just wanted to get the full potential of the elect sway bar. It will flex quite a bit more than the Mopar links will let it even with Mopar lift springs. I switched to rk no limits when I was still on the Mopar lift. Made a significant difference.......Mine is almost parallel with the ground. Slightly pointing up. With mopar lift. The mopar sway bar end link are just like factory ones where the ends pivot vs a thru bolt where it wouldn’t pivot so I find it hard to believe they wouldn’t be okay. Maybe not.
Looks like you are running the Metalcloak discos. How do you like them? We have a 3.5" Teraflex lift and those links seem to be a one size fits all. They simply say 12" on the website whereas every other manufacturer tells you what lift their link will cover. How do you like them so far? Quality?This where mine are and I'm pretty sure it's right. But I am curious if that's the case. Rides just fine.
Currently on my Rubi I have the 3.5" Teraflex lift with their sway bar links. WOW, they REALLY pitch the swaybar up way past horizontal. PO never had any problems and did some very serious rock crawling with it but it looks really odd to me since I was always told the sway bar should be around 4 degrees above horizontal.Yeah they’ll work fine, I just wanted to get the full potential of the elect sway bar. It will flex quite a bit more than the Mopar links will let it even with Mopar lift springs. I switched to rk no limits when I was still on the Mopar lift. Made a significant difference.......
