AFE Dry Air Filters. Drop In.
AG30
Akil
Edmonton, AB
2018 Jeep Sahara JLU, Ducati Monster 796
@AG30
Not sure if any other guys with the 2.0 have adopted the afe as of yet.. With that said, you may have to just do the deed blindly in regard to your install of the AFE.
I run an aFe Power 31-10280 Performance Air Filter ... the flat panel dry air filter. Actually, just cleaned it again yesterday. I'm real happy with the filter. Cleans up easily and dries out very fast after cleaning.
About your install... You don't need to loosen the band clamp, just fully loosen the screws that secure the air filter housing cover. After they are all loosened, gently pull up on the filter cover and it will rise... you may have to go back and loosen more one of the screws. Anyway, the housing cover will now be able to be lifted up just enough to slide out the old, to get a vacuum nozzle to vacuum out any debris in the housing and to slide in the new filter in....then drop down the cover and refasten the screws..
IF, if say you bought the cone shaped afe or you have trouble getting the cover up enough on hyour 2.0, do know that those 2 hoses you asked about are quick disconnect hoses. Press in firmly on the light colored tab on the hose and put gently but firmly and the hose disconnects. The press/click right back on.
IF you bought the cone shaped afe, you will have to loosen the band clamp and the screws and physically remove the air box cover in order to get the cone shapped afe in.
afe flat/dry for 3.6 and 2.0
Thanks for the help. Much appreciated. I actually only bought the Pro Dry S 3 Layer, the one you are showing in the pic. I'm hoping it works out nicely.
AG30
Akil
Edmonton, AB
Forgot to mention.. Normally, I would spray/soak the afe dry filter with Purple Power 4319PS Industrial Strength Cleaner and Degreaser, then rinse it down, shake it vigorously to get most of the water out of it and then leave it outside in the heat to dry for a few hours and then reinstall.
Yesterday, when I went to clean I found I was out of Purple Power... SO, I soaked the afe dry filter with Windex with Vinegar, (that is all I had on hand) let it sit for about five minutes and rinsed well...
Ya know, that Windex with Vinegar did the deed well.. must have degreaser or whatever in it as the filter cleaned probably up just as well as if I had used the Purple Power. (my filter was not all that dirty though to start with)
https://www.amazon.com/gp/product/B07BC59YVR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I'll keep this in mind. For now, I just purchased the AFE cleaner, but maybe I'll try some of these options when I run out.
Rhinebeck01
2018 2dr. Rubi
@AG30
Don't say "only bought" .... that is an excellent way to go for your JLU. IF you are like myself and others you will probably even feel the difference with the filter the day you install it. Also, the filter will pay for itself over the long haul so to speak.
garyji
Gary
Western NC
2017 JK Sahara, 2021 JLU Willys
That's the one I'm using. Love it. Not going to do oiled!!
G.
AG30
Akil
Edmonton, AB
@AG30
I hear ya. I was just meaning I didn't know about the cone shaped one. I'm pretty new to making some changes on the jeep, so the only wasn't a slight against the product.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
The filtration can’t be good enough for long engine life with these high flow reusable filters. I’ve looked at their numbers over and over and just can’t see the value in using anything other than a Wix.
Morris 4x4 Center
