Had time to get impressions on the ride quality? Flex?2DR dualsport 2.5” lift installed, first one?
Yes got a few miles on it now.Had time to get impressions on the ride quality? Flex?
Thank you for your insights. I'm hoping to avoid lifting, but I do see a need for stiffer springs as I keep adding weight with skids, winch, bigger tires, etc.Yes got a few miles on it now.
Rides great, I describe it as more car like, stiffer and more responsive. The jeep is pretty light(thinking i got 3+” of lift) but it still rides great, yes better than stock and still not harsh at all. Id say with a heavier rig would be even better but as of right now, maybe a little bit of armour and proper rock sliders is all i will add so it wont change much. I would recommend this forsure, especially to anyone that daily drives the jeep
Yes just went to test the flex, it lifted it alot like i said and made the 35s look a little small imo but it still stuffs them at full bump.
Don’t do it! Weight is the killer! On my Jeep and me hahaThank you for your insights. I'm hoping to avoid lifting, but I do see a need for stiffer springs as I keep adding weight with skids, winch, bigger tires, etc.
Sliders on the way, I seem to be falling right back into the previous Jeep's pitfall.
Need to reverse direction, but quick. lolDon’t do it! Weight is the killer! On my Jeep and me haha
I can only speak for the aev ones, plus you can just buy the springs. But yeah, its a true 2.5” with weight. If your heavy its the ideal coil, if not you’ll get a little more lift but its still a nice ride. Its crazy how noticeable the diameter of the spring is larger than the stock springs.I am still looking at all the options for my springs. I don't plan to buy a complete kit as the shocks i want are not in one. I really want to keep it as low as I can for a multitude of reasons. I was looking at the AEV 2.5" springs, they seem pretty nice and I am sure the quality is great. Right oe looking at AEV 2.5" springs, EVO 2.5" plush ride springs, Synergy 2" springs, teraflex 2.5" springs and the dynatrac 2" lift. I would prefer a true 2". I like the dynatrac, but have no use for the shocks. May end up with that and sell the shocks that come with it. Also thinking of the Mopar springs. I want a spring that will hold up to lots of miles offroad. AEV seems like it may be one of the better long term.
I plan to run the Fox factory race 2.5" remote res. Shocks, and will have a full skid system with a winch etc. so weight should not be an issue. My biggest hurdle has been finding spring specs. Synergy does great and gives you the compressed, extended, and spring rates for all of their springs. It is easy to see what you are getting and match it to other components. So far I have not found the same specs for any of the others.I can only speak for the aev ones, plus you can just buy the springs. But yeah, its a true 2.5” with weight. If your heavy its the ideal coil, if not you’ll get a little more lift but its still a nice ride. Its crazy how noticeable the diameter of the spring is larger than the stock springs.
Also agree, hopefully next year i can convince myself to ditch the Bilstein 5100 and go with fox or something thats a little softer for my setup, i think that would make it perfect
Sounds like a nice set up. Nope, just part numbers etc. No specifics.I plan to run the Fox factory race 2.5" remote res. Shocks, and will have a full skid system with a winch etc. so weight should not be an issue. My biggest hurdle has been finding spring specs. Synergy does great and gives you the compressed, extended, and spring rates for all of their springs. It is easy to see what you are getting and match it to other components. So far I have not found the same specs for any of the others.
You mention that the AEV coils are thicker, did any of the material give you the spring rates, or extended or compressed length?
I keep thinking about aluminum bumpers, and loosing the spare, loosing the winch, and whatever else I can to go light weight.Hopefully, AEV comes out with the bumper and the tire carrier before I decide on something else.
This. Is. Getting. Ridiculous.Hopefully, AEV comes out with the bumper and the tire carrier before I decide on something else.
