Advice on lift kit shocks 30mph trails...
Reabob
Montreal, Quebev
Wrangler JL Sahara unlimited 2018
Hi, i have a 2018 JLU Sahara. I want to lift 2-2.5" but,this is important, i want a very smooth ride on trail going relatively fast...
For the kind of off-road trails i do, everyone tells me to put budget boost. But when i hit trails we often have a main trail with passes on the side. So usually a stock Jeep can follow without going in the passes.
But my concern is that most of the Jeep have big tires, lifts, better shocks, etc...
In the main trail they can go quite fast (about 30mph, look picture for type of road i am talking about). But for me and my girlfriend which has back problems, it is very uncomfortable to follow at that pace.
Finally, which kit do you think would give me a good comfort on road but also absorb impacts and allow us to follow bigger rigs?
Can i get something under $1300 ?
AccuTunedJL
El Cajon, CA
2018 Jeep JL Rubicon
Unfortunately when it comes to ride quality, at speed, with a solid axle Jeep... its not going to be cheap. Just a set of tuned Fox 2.0 R/R shocks would run you around $1400-1500. I assume you are lowering tire pressure for traction & comfort?
MarkY3130
Denver
2019 JLUR
I agree on the tire pressure question. What PSI are you going down to? Even on easy to moderate trails where it is needed for traction, it makes a world of a difference in comfort.
On non-beadlocks I've run with 37" tires at 12 PSI a lot and it is much more comfortable!
Reabob
Montreal, Quebev
Hi, yes i lower them to about 16psi. But never disconnected. Would it help?
Reabob
Montreal, Quebev
33inches around 16psi
AccuTunedJL
El Cajon, CA
Disconnecting sway bar is really for slow speed rockcrawling. It wont affect comfort, but will affect control.
Reabob
Montreal, Quebev
I was looking into this lift kit ( yes i also want a lift!) . I guess it should be better with this than stock Sahara shocks?
JKS Manufacturing Suspension Lift Kit 2-1/2" With FOX 2.0 Shocks And Standard Coils 4-Door Jeep Wrangler JL 2018-2020
117kf kit wirh fox shocks version
Rubitrux
