- Kevin
- Jul 12, 2021
- Flagstaff, AZ
- 2020 Jeep JT, 1969 Wagoneer
- Build Thread
- Link
- Occupation
- Lighting Adventures Since 1970
Known for being one of the most versatile lights in the KC® family of products, the New Cyclone V2 now features replaceable polycarbonate lenses, higher output and is more adventure-proof than ever. This universal light is the perfect fit for any tight application and ready to help you Adventure Further®.
BUILT FOR ADVENTURE
The 5W Cyclone V2 LED light uses a multi-functional compact design delivering 600 lumens of LED output and is incredibly bright.
Originally designed for Off-Road Racers as an interior dome light, the Cyclone LED light has evolved into an all-purpose light for rock crawling, engine bays, wheel wells, truck beds, grills, bumpers, and an infinite amount of lighting applications.
We completely revamped the original Cyclone! We took a lot of customer feedback and incorporated it into this light. From new swappable lenses, to brighter output, to sleeker aesthetics, the new V2 is the way to go!
FEATURES
-3 Lens Color Variations: Clear, Diffused, or Amber
-5W 2.2" Multi-Functional Accessory Light
-IP 68 Rated Waterproof Die-Cast Aluminum Housing
-600 RAW lumens of light output for vibrant visibility
-Replaceable Colored Lens Options
-Flood Light Pattern
-Easy Attachment via Dzus clip or Hardware
-Each Light Sold Individually
AVAILABLE COLORS AND OPTIONS
-Single Cyclone V2 LED Lights (available in Clear, Diffuse, and Amber)
-Two Light Cyclone V2 Under Hood Lighting Kit (Clear only)
-Six Light Cyclone V2 Rock Light Kit (Clear and Amber)
-Single Colored Lens Kits (Clear, Diffuse, Amber, Red, Blue, Green)
-Six Pack Colored Lens Kits (Clear, Diffuse, Amber, Red, Blue, Green)
-Cyclone V2 Mounts (Flush Mounts and Surface Mounts)
LIGHT PERFORMANCE
-Raw Lumens: 600 lm
SPECIFICATIONS
-Wattage: 5W per light
-LED Source: 15 x Samsung SMD 3035 LED
-Amp Draw: 0.40A
-Voltage: 9V-16V
-IP Rating: IP68
-Product Dimensions: W - 2.20" x D - 0.53"
COMPACT, VERSATILE & EASY TO INSTALL
The 5W Cyclone V2 LED light uses a multi-functional compact design delivering 600 lumens of LED output and is incredibly bright. Originally designed for Off-Road Racers as an interior dome light, the Cyclone LED light has evolved into an all-purpose light for rock crawling, engine bays, wheel wells, truck beds, grills, bumpers, and an infinite amount of lighting applications. This is due to its compact 2.2" diameter, flat .53" height, and bright flood pattern.
LOW DRAW
Offering an efficient high-output to draw, it's not uncommon to see over a dozen Cyclones installed on a rig. Everywhere from the under the hood, wheel wells, the underbelly, to the interior of your cabin - it's never been easier, to put light where it's needed.
UNIVERSAL MOUNTING OPTIONS
Cyclone V2 LED lights feature a die-cast aluminum housing with a centrally located universal mounting hole. These Cyclone kits come with the necessary hardware to attach your Cyclone LED light(s) under the hood of your vehicle with minimal installation time, effort, or fuss.
WHENEVER YOU WANT THEM
KC has focused on mounting solutions for popular applications such as surface, angled, and flush mounts. While still utilizing the signature center mounting hole, the Cyclone V2 now features a provision to integrate a magnetic mounting solution for more ways to customize your nighttime adventure experience.
RACE TO ADVENTURE DURABILITY
Cyclone V2 LEDs use a die-cast aluminum base that provides strength, rigidity while providing great heat dissipation. The impact-resistant polycarbonate hard-coated lens will survive the toughest of terrains. Rated at IP68, the Cyclone V2 LED is sealed and water-resistant giving you the flexibility to traverse into the most demanding trails.
