Adventure Further with the ALL NEW CYCLONE V2 Lights!
KC HiLiTES
Rock Sponsor (Level 1)
Kevin
Williams, AZ
2020 Jeep JT, 1969 Wagoneer
Lighting Adventures Since 1970
Known for being one of the most versatile lights in the KC® family of products, the New Cyclone V2 now features replaceable polycarbonate lenses, higher output and is more adventure-proof than ever. This universal light is the perfect fit for any tight application and ready to help you Adventure Further®.
BUILT FOR ADVENTURE
The 5W Cyclone V2 LED light uses a multi-functional compact design delivering 600 lumens of LED output and is incredibly bright.
Originally designed for Off-Road Racers as an interior dome light, the Cyclone LED light has evolved into an all-purpose light for rock crawling, engine bays, wheel wells, truck beds, grills, bumpers, and an infinite amount of lighting applications.
We completely revamped the original Cyclone! We took a lot of customer feedback and incorporated it into this light. From new swappable lenses, to brighter output, to sleeker aesthetics, the new V2 is the way to go!
FEATURES
-3 Lens Color Variations: Clear, Diffused, or Amber
-5W 2.2" Multi-Functional Accessory Light
-IP 68 Rated Waterproof Die-Cast Aluminum Housing
-600 RAW lumens of light output for vibrant visibility
-Replaceable Colored Lens Options
-Flood Light Pattern
-Easy Attachment via Dzus clip or Hardware
-Each Light Sold Individually
AVAILABLE COLORS AND OPTIONS
-Single Cyclone V2 LED Lights (available in Clear, Diffuse, and Amber)
-Two Light Cyclone V2 Under Hood Lighting Kit (Clear only)
-Six Light Cyclone V2 Rock Light Kit (Clear and Amber)
-Single Colored Lens Kits (Clear, Diffuse, Amber, Red, Blue, Green)
-Six Pack Colored Lens Kits (Clear, Diffuse, Amber, Red, Blue, Green)
-Cyclone V2 Mounts (Flush Mounts and Surface Mounts)
LIGHT PERFORMANCE
-Raw Lumens: 600 lm
SPECIFICATIONS
-Wattage: 5W per light
-LED Source: 15 x Samsung SMD 3035 LED
-Amp Draw: 0.40A
-Voltage: 9V-16V
-IP Rating: IP68
-Product Dimensions: W - 2.20" x D - 0.53"
COMPACT, VERSATILE & EASY TO INSTALL
The 5W Cyclone V2 LED light uses a multi-functional compact design delivering 600 lumens of LED output and is incredibly bright. Originally designed for Off-Road Racers as an interior dome light, the Cyclone LED light has evolved into an all-purpose light for rock crawling, engine bays, wheel wells, truck beds, grills, bumpers, and an infinite amount of lighting applications. This is due to its compact 2.2" diameter, flat .53" height, and bright flood pattern.
LOW DRAW
Offering an efficient high-output to draw, it's not uncommon to see over a dozen Cyclones installed on a rig. Everywhere from the under the hood, wheel wells, the underbelly, to the interior of your cabin - it's never been easier, to put light where it's needed.
UNIVERSAL MOUNTING OPTIONS
Cyclone V2 LED lights feature a die-cast aluminum housing with a centrally located universal mounting hole. These Cyclone kits come with the necessary hardware to attach your Cyclone LED light(s) under the hood of your vehicle with minimal installation time, effort, or fuss.
WHENEVER YOU WANT THEM
KC has focused on mounting solutions for popular applications such as surface, angled, and flush mounts. While still utilizing the signature center mounting hole, the Cyclone V2 now features a provision to integrate a magnetic mounting solution for more ways to customize your nighttime adventure experience.
RACE TO ADVENTURE DURABILITY
Cyclone V2 LEDs use a die-cast aluminum base that provides strength, rigidity while providing great heat dissipation. The impact-resistant polycarbonate hard-coated lens will survive the toughest of terrains. Rated at IP68, the Cyclone V2 LED is sealed and water-resistant giving you the flexibility to traverse into the most demanding trails.
KC HiLiTES
KC HiLiTES
Kevin
Williams, AZ
These are dope! I like the idea of swappable lenses combined with the brightness - I could see these working as camp lights as well as rock lights.
Oh yes definitely. They are great for camping. Here are a couple of the V1 Amber Cyclones used for camping lights. Attached to the top of a roof rack facing down. This is my son's JK. Uses them for cooking on his tailgate table a lot.
TrailSnail
Josh
Gilbert, AZ
'21 JL Unlimited Sport S
DAMN those are bright! Nice!!
brewski
Jack
Washington
JLUR-diesel
@KC HiLiTES Thanks for doing the giveaway, cool of you to do and I hope I win.
I do have a question, you guys say these are brighter, but my V1s said they are 1100raw lumens and V2s are advertising 600raw lumens. I'm a bit confused since both are RAW lumens. Was there some V1 version that had brighter LEDs? Mine are 5-6years old from when I built my trailer. I had a couple V1s still in packaging that I was going to get some more to make rock light kit out of and noticed this new version.
Here is the output of 2 Cyclones (#1350) on my trailer.
KC HiLiTES
KC HiLiTES
Kevin
Williams, AZ
Hello and thank you for the acceptance! New to the Jeep community and would love to have a set of these!
You bet, and welcome to the community. Make sure to hit that link to the giveaway thread to enter if you haven't already. Good luck!
KC HiLiTES
KC HiLiTES
Kevin
Williams, AZ
Great set up! I believe the V1 Cyclones were 516. They pulled the old specs. Let me go dig them up.
KC HiLiTES
KC HiLiTES
Kevin
Williams, AZ
Yes we show the V1 Cyclones at 516 Raw Lumen for one light. I just found out that there was a batch with a misprint on some of the older V1 cyclones.
brewski
Jack
Washington
JLUR-diesel
See the back info. Says 1100 lumens. Clearly I have some of those. Thanks for looking into it and resolving my confusion.
KC HiLiTES
KC HiLiTES
Kevin
Williams, AZ
Yes those are definitely older ones with the misprint. Sorry for the confusion. This still shows the old style KC logo too. This is the older packaging also. They were replaced with the new KC logo and Black/Yellow Packaging before being discontinued for the newer V2 model.
trekster
Trekster
Golden Colorado
2021 JL Rubicon Extreme Recon
BUILT FOR ADVENTURE
FEATURES
LIGHT PERFORMANCE
-Raw Lumens: 600 lm
SPECIFICATIONS
-Amp Draw: 0.40A
-Voltage: 9V-16V
-IP Rating: IP68
LOW DRAW
BUILT FOR ADVENTURE
FEATURES
LIGHT PERFORMANCE
-Raw Lumens: 600 lm
SPECIFICATIONS
-Amp Draw: 0.40A
-Voltage: 9V-16V
-IP Rating: IP68
LOW DRAW
trekster
Trekster
Golden Colorado
I've got my 2021 JL Rubicon on order, it would be great to win these lites to install on it.
KC HiLiTES
KC HiLiTES
Kevin
Williams, AZ
Congrats on the new Jeep coming! The contest ended this morning. We have them on our web though. Let me know if you have any questions.
Hothead Headliners
